G
greatestboss
Happy New year to you Trebdp83, William Lemmerhirt and all distinguished members of this great forum.And a Happy New Year to you and all!
The main differences will be how the auto setup and room correction software deal with things. Ypao, mcacc audyssey, Dirac and anthem etc all do it a little differently. No way to know what one will do differently vs another. Another key is navigating menus. For ME, while I do like the performance of many Yamaha AVR’s, I will never buy another one. Simply because I really dislike the menu structure, and they’re proprietary language and one off ways of doing things. Mostly the other brands are navigable and intuitive enough. I do enjoy my Marantz a lot despite some small quirks and willThank you so much for your valuable input, Buyers remorse, that is the key and decisive word.
FYI, in here The Denon AVR-X6800H is for $3,410
Marantz C30 for $4,055.
Anthem MRX-1140 for $4,950 (I wonder how it compares to the C30)
Thank you for your sound advice.The main differences will be how the auto setup and room correction software deal with things. Ypao, mcacc audyssey, Dirac and anthem etc all do it a little differently. No way to know what one will do differently vs another. Another key is navigating menus. For ME, while I do like the performance of many Yamaha AVR’s, I will never buy another one. Simply because I really dislike the menu structure, and they’re proprietary language and one off ways of doing things. Mostly the other brands are navigable and intuitive enough. I do enjoy my Marantz a lot despite some small quirks and will
Use it for a long time.
For you, it seems to me that the price hike from the denon to the Marantz isn’t high enough to be a deal breaker, while the difference from the Marantz to the anthem, almost 1k, while being roughly 1500 over the denon.(can buy a very nice AVR for that price gap lol) I estimate that to be well into diminishing returns, which of course for most people that would qualify. But if you have an ample budget, only you can decide where that line is. From here, it looks like the Marantz is right about where your comfort level is if not slightly above. FWIW, I think you’d love it.
And also, happy new year to you!
Your welcome! Hopefully I can help. Even a little.Thank you for your sound advice.
Got the X15, I hope it performs as good as it looks. So excited to get it delivered.Your welcome! Hopefully I can help. Even a little.
Thanks @Trebdp83for the advice, I'll try it and will let you know if the issue is resolved.Try reconnecting it to the Cinema 30 and open the Setup menu to the 4K/8K Signal Format settings. Set the cable box to 4K Standard. Then, go to the HDCP Settings. Set the HDMI port used by the cable box to HDCP 1.4.
If the cable box is the beIN 4K, it will probably output the 1080HD signals without upscaling using the new settings and the TV will do the upscaling of the signal. See if that does the trick.
I tried it and did all the settings you mentioned, still it didn't work. Signal goes, loss of Video and Audio for 2-3 seconds.Try reconnecting it to the Cinema 30 and open the Setup menu to the 4K/8K Signal Format settings. Set the cable box to 4K Standard. Then, go to the HDCP Settings. Set the HDMI port used by the cable box to HDCP 1.4.
All my cables are Audioquest and I believe they are Ultra Certified cables. I've set it to 1080i and it still gave me the same issue. I really don't know what to do other than Connecting the Video directly to my TV and use the Optical from the beIN to my Marantz, I don't know if this will impact the Audio quality.If there are any handshake or signal issues, they can only get worse when going through an AVP/AVR. With new systems, I always recommend Ultra Certified cables all the way around. This still may not help with some devices.
If the beIN is still actually sending a 4K signal, see if setting it to output 1080i or 1080p @60Hz works. The TV will upscale it.
Thanks Trebdp83, Question: if I connect the beIN directly to the TV HDMI 4 through Audioquest HDMI cable and disconnect the Optical from the beIN to Marantz, will the Audio from the beIN come through the TV eARC to the Marantz eARC lossless (Atmos/DD+). The eARC cable is connected already from the TV to the Marantz eARC because I use the Sony Netflix button.Some devices have HDMI and HDCP specs that may trip up a system supporting the new HDMI and HDCP specs. TVs are usually more forgiving of them when directly connected to them. There optical connection will get you up to DD and DTS 5.1.
You can use eARC to get audio from devices connected directly to the TV back to the Cinema 30. Make sure the Cinema 30's eARC port is used to connect to the TV's eARC port. Set the TV's eARC settings to Auto and the digital audio output to Passthrough.
You could also use the optical cable from the TV to the Cinema 30 to get audio from any device connected directly to the TV via HDMI to the Cinema 30. But, Atmos/DD+ from streaming services from a directly connected device or the TV's service apps requires at least ARC. If a disc player, game console or streamer capable of outputting multichannel PCM signals is used, eARC will need to be enabled for the extra bandwidth needed for lossless multichannel signals.
TksYes. Make sure eARC is set to bitstream/passthrough, NOT PCM. If there are settings for each HDMI input port, make sure they are set to bitstream/passthrough as well.
And what does Tks mean?
Thank you Trell.And what does Tks mean?
I have those two options on my TV for the eARC, which one I should set for bitstream/passthrough (Auto or Off).Yes. Make sure eARC is set to bitstream/passthrough, NOT PCM. If there are settings for each HDMI input port, make sure they are set to bitstream/passthrough as well.
