I visited a small tech store today and they had a cheap 70" LG model on display. I was siting a little over a meter away from it and I said to myself "man this is small"... I watched a few movies on my parent's 55" Oled and I have to say, there is nothing like the perfect Oled picture quality but the size... I had to seat as close to the TV as I could to enjoy it and the experience was still subpar. I can easily afford a 65" Oled but I have seen them from up close and they are still too small and the price increase of the 77" one is unreasonably high and unfortunately well outside my budget.
I will have to visit a bigger tech store which is in another city and have a look at the new 2020 75+ inch models and see if they are sufficient even If I have to seat a little bit closer than I had originally planned. I heard positive things about the new models so I hope their quality reminds me a little bit of the Oleds. I am willing to sacrifice a little bit of quality for the bigger size as long as the blacks are not noticeably bad.
Thank you for asking them! Since we now know for sure that's the case that could be a deal breaker. The big plus with the laser projectors is the uniformity of their picture over the years unlike the lamps that slowly lose quality over time. I know this in theory though, since I ve never owned a projector I don't really know how much the quality is affected after 500, 1000, 1500 and finally 2000 hours.
Since you have experience on this matter could you please let me know how much is the quality affected? For example are you looking forward to change the lamp after a couple of hundred hours or after a thousand hours of usage due to the quality reduction or do you see a noticeable difference only when the time to change the lamp comes?
Doing the math like you did is not a bad idea! The Optoma P1 costs 4K euros and I found lamps for the epson 6050 for a little over a 100 euros. The epson costs 2500 euros so I will have to change the lamp about 14 times to reach the price of the optoma. 14*2000 hours = 28000 hours which are not only more hours but after that the optoma will need replacement but I can keep buying lamps for the epson and keep going until another component fails. The only issue is the quality reduction over time which I don't know if it has an impact on the overall home theater experience.
The epson was just an example. It was one of my lamp based picks when I first started looking for a projector. The pixel count is half that of the rest of the e-shifters but from the reviews I ve seen they say they look sharper due to their excellent contrast. Then again their good blacks are due to their iris, as far as I know, which is quite slow so I don't really know how good they are with their iris turned off.
That second picture!!! Gorgeous!!! I have seen ceilings like yours with the star effect and man do I love them! The roof of my house is not flat so I don't know If I can do something similar but even If I can I don't know where to start...
I see in the first picture your center channel is blocking a little bit of your screen (It could be the picture angle though). Did that bother you while watching movies? I am asking this because I was thinking that I could go with a 120" screen If I go with a projector and place the speakers at the front. A little bit of the top of the speakers will block the sides of the screen but is it actually noticeable when you are watching a movie on such a large screen?
So am I right to assume that a decent 2-3 grant 4K projector can be on par with a decent LED TV?
This is what I noticed with my parent's 55" TV. They had a 32" TV so understandably for them it was a big upgrade. It turns out you get used to a small TV quite fast and my father keeps telling me he should have gone for the 65" one but at the time the price difference was enormous... When we visited a couple of big tech stores though and he saw the 75"+ ones he said "Those wouldn't be half bad either"
I guess you should base the screen size on your sitting distance and get the biggest screen you can...
I can imagine
Playing a war game on a good Atmos system must take things to a whole other level!!
This is such a painful truth.... I truly hate the black bars... This is actually one of the reasons why I can't enjoy content on smaller TVs because the content itself makes the TV looks smaller... When 16:9 content appears is like watching on a different TV....
This is a huge plus for the projectors since even the original Ben Hur can look immersive on a huge screen!
I mentioned the epson above, that was before I saw your comment. I would really appreciate your input as well on my question above for both the lamp quality reduction over time and the sharpness & quality of blacks with the iris turned off.
Like the bigger screen size I bet the same applies with the image quality. Unless you buy the absolutely best thing on the market you will always crave the better one
