7.1 Home theater system
MJBueta
I need help in buying av receiver for my Wharfedale crystal series 4.3 floorstanders, 4c center and 4.1 surround, Elacs' s10eq subwoofer and atmos 4.2A. Please give advice and recommendations. Thanks
shadyJ
Speaker of the House
What do you want help with exactly?
shadyJ
What is best recommended av receiver should I buy with the above mentioned set of speakers to set up a 7.1 home theater system.
I would look at Yamaha, Denon, Marantz, with whatever feature set appeals to you the most. There is not going to be big differences in AVRs in this price range.
Pretty much any of them so narrow it down by your budget and the features/connectivity you want....I agree with sjadyJ on the main brands to choose from.
MJBueta
What's the right amplification should I look at?
MJBueta
Specs:
Floorstander 4.3- 120w, 8ohms
Center 4c. - 100w, 8ohms
Surround 4.1. - 60w, 8ohms
Elac 4.2A. - 80w, 6ohms
Subwoofer. - 200-400w
Specs:
What has that got to do with budget? Speaker wattage ratings aren't very useful for determining amp needs, more about sensitivity and impedance (and generally avrs are suited for 6/8 ohm speakers, sometimes for lower impedance speakers at high levels another amp solution (like external amps) might be a thought, so might want an avr with pre-outs to accommodate such.
The subwoofer is a passive sub? Most avrs (except for some htib type) won't work as they don't have an amplified sub channel.
Might play around with this to determine your amp power needs http://myhometheater.homestead.com/splcalculator.html
shadyJ
Specs:
Pretty much any receiver in the $700 to $1000 range will be adequate to power your setup.
MJBueta
Thanks
2
2channel lover
The best way to handle this imo is buy the lowest priced AVR with the feature set you want and to that make sure you have pre-outs for the 7 channels...then in the future if you move into a place with a larger room or you feel the AVR is not quite up to the task you can always add an exterior amp.
Buying one with mostly the same features but 30 wpc more than the next model down is pretty much worthless when it comes to output.
