5 Screen Channel Wiring
X
xzk493277
Does anyone know how you would go about wiring 5 screen channels with only 3 channel outputs? I want to wire a speaker between the left and center channel to get a combination of the two, and also wire a speaker between the center and right channel for the same purpose. Is this feasible? I can calculate the stress on the amps (which will not be a problem anyway), so I don't need info on that just proper positive and negative connections between the speakers if possible. Thanks.
everettT
everettT
Your asking for a sound disaster. If your unsatisfied get a better front 3. Can you list your current gear?
Don't know why you'd want to do this, but a mixer might be what you need as well as more amps.
X
xzk493277
This is an experiment, not a permanent setup, to mimic a 5 screen channel setup.
The 5 speakers are all JBL 4670 (2-way). The amps are all Crown XLS 2502.
everettT
everettT
I can tell you that unless your expecting anything other than a horrid soundstage, not much to experiment with. JBL, QSC,and others make systems that will accomplish what you want, but wasnt intended for the layout you described.
