5.1 system for under $1000
rojo
rojo
I'd try the NXG behind that French door and find a new home for the DVD rack that currently lives there. If not there, then maybe in the corner where the bistro set is next to the drapes.
afterlife2
afterlife2
That corner where that picture frame on floor is, is a perfect spot.
V
varsis
Yea that won't happen with the gf she is picky where stuff goes. I am thinking put it in the den (room where the French doors go) under a desk and just have the doors open when watching tv/movies. Doors barely get closed as it is.
Or
Get a smaller sub and put it next to the fire place or so.
zieglj01
zieglj01
Or
I would try to stick with what you have.
However, if you have to go smaller and want to augment the bass
with your front speakers - then I would look at the Atlantic Tech
8 inch subwoofer - the front firing one is $278
http://www.amazon.ca/Atlantic-Technology-SB-900-BLK-Front-Firing-Subwoofer/dp/B005CUC8BW/ref=sr_1_fkmr1_2?ie=UTF8&qid=1429918953&sr=8-2-fkmr1&keywords=atlantic+tech+8+inch+subwoofer
KEW
KEW
There is a great 8" sub (originally $900 and designed by Velodyne) that has been sitting in classified for awhile (you may have gathered, this is not the best place to sell an 8" "sub"woofer):
http://forums.audioholics.com/forums/threads/fs-velodyne-photon-8-subwoofer-and-dana-630i-bookshelf-monitor-speakers.92847/#post-1068702
I have a pair and they are tight!
This would make a superb woofer (really hard to call 8" a sub) and fill out the sound for music. As a subwoofer, it will lack for LFE, but you cannot really expect that from 8".
It is over your budget, but has been sitting there for a while. Perhaps you can stretch and Alphiii can stretch to make it work?
Here is a review with measurements:
http://www.audioholics.com/subwoofer-reviews/photon-8-subwoofer
Their conclusion (which fits my experience):
Despite its small size, the Photon-8 can output some unexpectedly deep bass at very respectable SPL levels while still maintaining a characteristically musical sound quality. The bass output was always solid, details present at bass frequencies in the recording were not buried under murk, and transient response was always clean and crisp.
While a sub woofer of this size does have physical limits whose effect can only be minimized with good engineering, it certainly will have little trouble outperforming many larger but lesser subwoofer designs. This sub can definitely add some tactile excitement at the bottom and over taxation of the Photon-8 is remarkably unobtrusive with very little that is audible to give away the distress. Sonically it performs as if it is larger than it is, never sounding small, inadequate, or underpowered.
The Photon-8 is a good subwoofer by any measure and an excellent subwoofer when taking into account its small size. If one is in the market for the smallest subwoofer possible but loathes the fact that small subs usually have some severe limitations on actually performing as subwoofers, the Photon-8 just might be the answer
V
varsis
So ended up keeping all the original equipment. Some final pics. Really enjoying the system thanks everyone! Just need to get some wire cover trim now...
rojo
rojo
Very nice! Yeah, some wiremold will really clean up those surround wires. I take it you're pleased with the sound, then?
Looks like you added a coffee table as well. Does that interfere with the sound from your center channel? Was that a compromise for being able to keep your sub? :)
