5.1 speaker configuration for odd shaped room
  • Thread starter Thread starter bodyguard_29
I did come across a soundbar that I would like input on: the Definitive Technology Mythos XTR-SSA3.
Yes, I realize that by restricting my requirements for something that is narrow, I may be sacrificing some sould quality, but since I am not as much of an audioholic as others, I am willing to sacrifice some quality for aesthetics.
The bass will reach down to about 150 hz
Your decision - may you have fun and enjoy the adventure.
I am actually a bit offended by that comment. I strongly considered your recommendations, but when I looked at the size specifications, it posed a concern, so I decided to focus my attention on soundbars that were a bit more sleek. Does that make me bad or an idiot? I don't think so. Yes, maybe I analyze things to great detail, but that is because I don't want to be disappointed.
Their site says the range is 60Hz-30kHz. Am I not looking at it correctly? I am a novice when it comes to specs. I am assuming that the lower the number, indicates how low (deep) the sound can go, is that correct?
I put forth a lot of effort and research into helping you find options that would not only fit your placement requirements, but also to get you the best sound you can get within your limitations. Then I see, "It's not important what it sounds like." This is not an architectural or interior design forum. Sure, we value high wife acceptance factor and sexy finishes, but first and foremost we enjoy listening.
Def Tech probably includes room gain in their measurements, or perhaps places a measurement microphone directly in front of one of the mid drivers. I read on an independent review site somewhere, and forgive me for forgetting where, that the F3 is closer to 160 Hz if I recall correctly.
Edit: http://www.soundandvision.com/conte...ssa3-soundbar-xtr-20bp-surround-speaker-and-1
The review there is pretty favorable, but you're pretty limited by your subwoofer placement. If you cross your subwoofer too high, you'll hear fundamentals of voices and directional audio coming from behind you. It'll ruin the imaging. If your sub could be placed in front of the fireplace, it might not be as bad -- but that's not realistic. A better solution would be to get a sound bar with, perhaps a taller and thicker profile, but with larger drivers capable of playing deeper.
I do appreciate your time and research Rojo and I am not saying that sound quality is not important to me, it is. I just want something that is also aesthetically pleasing to myself and the girlfriend, to go along with the nice sound. It is your knowledge about things such as the misleading specs that really help me. I know that manufacturers may mislead people to sell their product, and with my lack of knowledge, I just compare what they print.
This is also why I research the hell out of things. One site may rave about a product, but then someone like you may uncover some true facts that dis-prove certain statements/specs.
Your knowledge is greatly appreciated.
Definitive like some other companies - are too optimistic with their specs
I have owned a few of their speakers - so I know from experience that you
can not go by their bass specs.
You have a good chance for 60 hz, with your ear close to the speaker.
Thank you everyone for all of the input. Have a great weekend.
After much consideration, I went with the Klipsch soundbar. Now for placement of my rear ceiling speakers. Should I place both of them along the back wall above the couch (approximately 8 feet apart), or should I place one above each corner of the couch, since the couch is a sectional? I am having uploading issues, so you can refer to the previous images of the living room.
Because my living space where we watch movies is such a mess acoustically (with stairs, the couch has to be to the side, and we pull the tv out from wall at an angle above fireplace), it didn't make sense to keep my Wharfedale Opus setup. Also no place to put rear surrounds that need to hang on wall. I sold the center and rears, moved the towers to the office, and got a SuperCinema XL. Currently using an old subwoofer, but will upgrade to a matching one by GoldenEar soon.
I hadn't used the sub in years since the Opus 3 went down to 23 Hz. I need to finetune the crossover. Also trying to decide if it'll be worth it to eventually get some small SuperSat speakers on stands. Maybe I'll share a picture of the space.
