• Thread starter wfnaegele@msn.c
  • Start date
W
wfnaegele@msn.c
My 5.1 system speakers were linked with 18 gauge wire.
Rewired it with 12-gauge, adding banana plugs.
Turned it on: nothing.:eek:
Removed banana plugs from one speaker [front right because it was the most accessible], attached wired directly: all five speakers came on.
Can someone clue in this clueless person?:confused:
mazersteven
mazersteven
Did you check to see if there was any protective plastic sleeve inside of the banana plug? Or something that would prevent a proper connection between the cable, and itself?
Midcow2
Midcow2
Sound like you have a short circuit and maybe also an open circuit.
If you have an ohm meter (buy cheap one at Radio Shack $10) and a alrgator clip test cable (buy at Radio Shack $5) you can quickly find the problem.
It sounds like you might have a whisker hair short. Make sure there are no wire strands protruding from the bananna plug. I sound like the speaker ou disconnected might be shorting. When you got no sound , did your AVr also power offf.
Disconnect cables from speakers and AVR. At one end of on one cable put one lead of ohm meter on cable put other end on other end of cable you should read close to zero ohms if note open circuit. This checks the integrity of each cable.
GlocksRock
GlocksRock
Did you notice any improvement in sound when upgrading the guage of your wire?
1
10010011
I bet the wire was not making a good contact inside the banana plugs.
Seth=L
Seth=L
If you re-read the OP you will see the upgrade was "no" sound.:D
Double check the connections, make sure there are no shorts and/or open circuits.
MDS
A sensible title will make people read the post. I initially thought it was spam due to the non-sensical title and email address as a user name.
Halon451
Halon451
My money is on the fact that it is a short circuit, and however it is occuring is causing your receiver to go into protect mode, that is why you're not getting any sound from the other speakers.
GlocksRock
GlocksRock
ok... once the banana plug was removed and sound started coming from all the speakers, did it sound any better?
