I'm considering using a Marantz SR8012 with some high-end Martin Logan speakers for the 3 channels at front. Someone at Martin Logan worried about this setup and said:
I would definitely recommend more power to drive the speakers more efficiently and provide less load on your receiver.
He then suggested 3 channel amps from Parasound (quite expensive at well over double the cost of the AVR) and Monoprice (not available in the UK).
From the review of the Marantz I know it's not the most powerful thing in the world with all those channels in use (I'll have a 7.2.4 setup), but I thought it might be good enough. However, is his concern valid?
If so, what 3 channel amp at a reasonable cost that is readily available in the UK would you recommend?
L/R speaker sensitivity: 90 dB/2.83 volts/meter, 6 Ohms, 0.7 at 20kHz Compatible with 4, 6, or 8 Ohm rated amplifiers.
Centre channel sensitivity: 90 dB/2.83 volts/meter, 6 Ohms Compatible with 4, 6, or 8 Ohm rated amplifiers.
They will be used with 2 active subs.
I'll be sitting around 2.5m away and want it capable of THX reference level sound.
