Official Japanese Press Release
[NEW PRODUCT] AVR-X3800H / AVR-X2800H / AVR-X580BT 8K/4K HIGH-PERFORMANCE AV SURROUND RECEIVER 3 MODELS FOR FULLY ENJOYING HIGH-DEFINITION AND HIGH-QUALITY CONTENT IN THE UHD ERA!
Sep 15, 2022
Denon will release the 9.4ch AV surround receiver "AVR-X3800H" and the 7.2ch AV surround receiver "AVR-X2800H" in late October, and the 5.2ch AV surround receiver "AVR-X580BT" in late September.
AVR-X3800H has 6 inputs/2 outputs out of 6 inputs/3 outputs, AVR-X2800H has 3 inputs/2 outputs out of 6 inputs/2 outputs, AVR-X580BT has all 4 inputs/1 output, up to 40 Gbps 8K/60Hz and 4K/120Hz video signal pass-through, so you can fully enjoy the new 4K/8K satellite broadcasting, video distribution services, and ultra-high-definition and smooth image beauty of the latest game consoles with high-quality sound. I can. Of course, in addition to simply supporting 8K, HDR (High Dynamic Range), which enhances the expressiveness of brightness and colors and improves the reality of images, supports HDR10+ and Dynamic HDR in addition to HDR10, Dolby Vision, and HLG. also supported. eARC (* Only AVR-X580BT does not support immersive audio) that enables input of multi-channel linear PCM signals from TVs, Dolby Atmos, DTS:X and other immersive audio signals, ALLM, VRR that innovates gaming & VR experiences, It also supports the latest features such as QFT, raising the quality of the home theater experience to new heights.
In terms of sound quality, bring out the true value of lossless audio and immersive audio, and reproduce sound that approaches the dubbing stage in your home theater. In order to embody the ideals that Denon's AV amps aim for, all models have undergone thorough sound tuning. The sound master Shinichi Yamauchi, who handles the sound quality tuning of all Denon products, and the sound quality engineer have accumulated over many years of knowledge, custom-made high-quality sound parts, and circuit design technology. All models have fidelity close to that of Hi-Fi audio.
The AVR-X3800H supports Dolby Atmos, DTS:X, MPEG-4 AAC, as well as IMAX Enhanced and Auro-3D. A 9ch amplifier is built in, and a surround system including 4ch height speakers can be constructed by itself. Furthermore, since it supports processing up to 11.4ch, you can use up to 6ch height speakers by adding an external power amplifier. In addition, up to four subwoofers can be connected, and the low-frequency components of nearby speakers can be assigned to each subwoofer, so bass directionality and movement can be accurately reproduced. . The pre-out is equipped with 11.4ch, and if you use the "preamp mode" that separates the preamp from the built-in amplifier, you can output a high-purity audio signal to an external power amplifier that is not affected by the operation of the built-in amplifier. . The preamp mode can be set not only for all channels at once, but also for each channel individually.
AVR-X2800H supports Dolby Atmos, DTS:X and MPEG-4 AAC. With a built-in 7ch amplifier, you can build a surround system including 2ch height speakers or surround back speakers. Up to 2 subwoofers can be connected.
The AVR-X580BT supports lossless surround formats Dolby TrueHD and DTS-HD, making it the perfect entry-level home theater model. Up to 2 subwoofers can be connected.
The AVR-X3800H and AVR-X2800H are equipped with the network audio platform "HEOS", and if you add HEOS Built-in devices such as "Denon Home series" smart speakers and sound bars to the system, you can enjoy wireless multi-room. You can easily build the environment. Music streaming services include Amazon Music HD*1, which supports lossless and high-resolution, AWA*1, Spotify*1, and SoundCloud*1. You can also enjoy internet radio broadcasts from around the world. It also supports AirPlay 2, so you can enjoy high-quality audio from Apple Music*1 and apps. For Bluetooth®, both reception and transmission*2 are supported, so you can enjoy TV audio and music with Bluetooth headphones. It also supports playback of DSD files and high-resolution sound sources stored on music servers (PC / Mac / NAS, etc.) on the local network and USB memory. It also supports voice control with Amazon Alexa. In addition to basic operations such as play, stop, skip, and volume adjustment, just talk to Alexa-enabled devices such as Denon Home and Amazon Echo. can be specified for playback. You can also call Internet radio stations by voice. It also supports "Denon AVR Remote" that allows you to operate and set the AV amplifier with a smartphone or tablet, and "Web control function" that allows you to operate and set with a web browser on your smartphone or PC. Wi-Fi supports 2.4/5GHz dual band, MIMO and IEEE 802.11 a/b/g/n/ac, enabling high-speed and stable communication.
In addition to receiving music signals via Bluetooth, the AVR-X580BT also supports the remote control application "Denon 500 Series Remote" that operates AV amplifiers via Bluetooth.
All three models have been redesigned with intuitive setup menus that have received high praise from the past. The display resolution of text and images has been increased to improve the readability of text and the visibility of images. The design has also been refined and reborn into a modern one. The "setup assistant" function, which provides easy-to-understand guidance on initial settings such as speaker connections and settings, input device connections, and network settings with text, images, and animations, has also evolved to make it easier to understand, and is displayed on the TV screen. Anyone can easily set up the AV amplifier just by following the instructions and proceeding with the settings step by step.
*1 Separate registration/contract and fee may be required to use the service.
*1 Headphone volume cannot be adjusted from the AV amplifier. Use Bluetooth headphones with volume control.
Denonの100年にわたる革新を体感しましょう。ホームシアターやハイファイ向けのAVレシーバー、スピーカー、ヘッドホン、オーディオシステムをオンラインで発見。
www.denon.jp
