N
noob0804
Hello all -
I bought a MyCloud NAS a few years ago when it supported DLNA. I have a lot of music in it, but my WiiM Pro doesn't see it because of the lack of DLNA. My question is if I can add a Synology DLNA NAS to my network (ethernet cable to the switch) to have my music visible from the NAS to the streamer. I'd keep the MyCloud for home/office/backup and use the Synology for media only. Would that work? I hope this is the correct forum. Thanks for your help. Every time I ask a question to the Audioholics I get all the information I need (and then some) :).
Trebdp83
Have you looked into using Twonky on the EX2?
Trebdp83
My own WD device still works using DLNA. I know some used Twonky on other WD devices but I never had to try to use it. Some also used Plex.
jinjuku
jinjuku
Moderator
Hello all -
Can you roll back to a prior OS release on the WD?
N
noob0804
Unfortunately WD forces the OS updates on the users without an option to opt out
N
noob0804
Other than the lack of DLNA the WD NAS has worked perfectly for our home office needs. My wife is not interested in streaming from the NAS, or from anywhere for that matter, so it’s only my dilemma…
N
noob0804
Thanks to all. I finally figured out how to do this.
BoredSysAdmin
BoredSysAdmin
This is my favorite type of comment. Dear OP, There is no need to post at least some details on how you resolved the issue. I'm certain no one else would ever run into the same or similar issue.
panteragstk
panteragstk
Yep. It's the best. You spend hours researching an issue only for the end to be...this.
N
noob0804
Sorry for both the late response and the plain "thanks to all..." With no elaboration.
The solution was suggested by an early response. I was able to install Twonky on my NAS from the WD website and the Wiim was instantly able to stream from it after a reboot of the NAS.
Thanks again!!
