ok, trying to learn here.
what exactly does -0 reference mean ? iiuc, its when the volume is all the way up, correct. -0 is all the way up on my receiver. but is there some kind meaning to this in the audio world ?
tia
Volume scales vary according to manufacturer and model. On my old AVR the scale was -100 to 0, IIRC. On my newer AVR made by the same company the scale is -80 to +20.
If I turned the old AVR up to zero, that would be the maximum the amps would play. It'd also hurt the speakers, because there's no extra room for the amp to play dynamic peaks. The amp would clip at those peaks and clipping hurts speakers.
In a -80 to 20 scale, playing sound at zero allows the amp to hold 20 dB in reserve for those dynamic peaks. There's no guarantee this set-up won't clip--some spike might need 30 exta dB--but it's fairly safe.
Some AVRs have user selectable scales, called "relative" and "absolute," IIRC (I never had one of these systems). A user might chose a straightforward 0 to 100 scale, or perhaps the -80 to +20 scale.
Chris
