The best part about someone saying these particular speakers are junk is I can say
"Well spend $29.90+s&h and try them for yourself!"
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-652
Having no crossover between amp and speaker might be part of their magic. I couldn't see buying another bookshelf sized speaker in the near future. The price point would probably need to be in the $1000+ range to actually sway me on an audible difference. The 70hz low end rolloff is the only thing that puts them in a "probably need to go 2.1" category. Best bet is don't underpower them since they are 4ohm and most home amps won't push hard/clean enough.
My opinion remains speaker building is 10% design, 10% execution and 80% luck. If pocket calculators could "calculate" a perfect speaker the best speakers ever would have been made around 1970 and never changed.
TOPIC UPDATE: I finally hooked the series triplestack up to the spec2 today. The results were very positive. Other than a slightly smaller vertical listening cone the
notable volume increase and power handling have allowed me to consider this a great success. Imaging is still very good and the high's have not sharpened up to a painful level as I had feared.
I originally started this whole thing because I recommended the Daytons to a friend and he loved them for his bedroom setup but he didn't think they would be robust enough for a larger home theater downstairs. I agreed with that assumption but nothing in his price range could pull off the actual sound quality+volume he was hoping for. So here we are. ~$45 per completed speaker and nothing can match that price with any quality.
As I said, Don't just judge. Try!
