Any amp can handle a 4 ohm load. It is a question of how much power they are expected to deliver to the load. An amp with a weak power supply such as we see in low end receivers might be rated at 80 watts into 8 ohms. That same amp may be perfectly happy deliverying up to 40 watts into 4 ohms. But rating the amp for 4 ohm use would require the amp manufacturer to lower the power rating which, oddly, is the most important spec for consumers. Most consumers would buy the 80 watt into 8 ohms amp rather than the 40 watt into 4 ohms amp even if they are the same amp. We are talking about a 3 db difference. Reality is few people actually run their amps at full rated power for any meaningful length time. Most receivers will drive 4 ohm loads at reasonable listening levels in typical family rooms or living rooms.
The following Denon FAQ sort supports what you are saying:
[h=2]
4 Ohm Speakers with Denon A/V Receivers or Power Amps[/h] Published 08/16/2007 10:35 AM | Updated 11/21/2011 05:06 PM
Can I use
4 ohm loudspeakers with my Denon receiver or power amplifier?
Yes, you can.
To understand this a bit better, first realize that all amplifiers are designed to deliver a signal into an electrical "load" or resistance presented by the loudspeaker. We measure resistance in units called "
ohms" (after the German physicist Georg Simon
Ohm, 1787–1854).
Conventional wisdom makes an 8
ohm loudspeaker load the most acceptable because it "protects" the amplifier from delivering too much current. A
4 ohm loudspeaker can encourage a marginally designed amplifier to deliver more current than it comfortably can.
However, you should remember that a loudspeaker’s impedance rating is a nominal or average one: A speaker rated at 8
ohms may actually vary from 5 (sometimes even less) to 20
ohms or higher, depending on the frequency at which you measure the impedance. We call this reactance. (Don’t worry about this too much -- good speaker engineers are well aware of these variations and take them into consideration when designing products.)
In general, you’ll find that Denon products are designed to function with a wide variety of loudspeakers and have power supplies and output circuitry more than able to meet the current demands of low impedance loads. If using
4 ohm rated speakers, common sense should always be taken as to the volume level setting, as it is easier to overdrive or "clip" an amplifier with
4 ohm speakers than with speakers with a rating of 6~16
ohms.
In the rare event that very low impedances tax the amplifier, quick acting circuitry will protect it from damage. If unusual operating conditions trigger this "Protection" circuitry, the receiver will shut down and you will see a red blinking light on the Standby indicator. If this happens, simply power the unit off, unplug the unit for 3 minutes, and then plug it back in and power the unit back on. The protection circuitry may reset if there's no internal damage within the receiver. If it re-engages, check your system for possible malfunctions such as intermittently shorting speaker wires, damaged speaker drivers, or it may be as simple as turning the volume down a little as not to cause the amplifier(s) to go into protection due to overdriving them.
