Which amps to hook up with a Bose acoustimass 10 system?
Discussion in 'Amps, Pre-Pros & Receivers' started by Albon, Aug 24, 2009.
  1. Albon Audiophyte
    Albon
    Aug 24, 2009
    6
    1
    Hi guys. Which amp should I buy for this type of system? I'm looking at the Denon AVR-790, the Pioneer VSX-1019 or the Yamaha HTR6250B right now. Do u have a best pick in these 3 or any other suggestions? Thanks! =)
  2. adwilk Audioholic Ninja
    adwilk
    Jan 23, 2006
    4,781
    2,535
    Doug's Basement
    I hear Fisher Price makes some decent amps.... :D
    Sorry couldnt resist.
    Yikes, you're about to get slammed for asking about Bose.. just a heads up. Their stuff doesn't play well with others and leaves a little to be desired in the world of non-marketed audio.
    Have you already purchased the acoustimass system?
  3. Albon Audiophyte
    Albon
    Aug 24, 2009
    6
    1
    No I dont. I'm just about to. I pay 900$cnd instead of 1200$. U guys dont think this system worth it? I pay 1400$CND with the Denon 790 or the Pioneer VSX-1019..
  4. lsiberian Audioholic Overlord
    lsiberian
    Nov 17, 2008
    12,238
    3,167
    On A Bridge in Fort Worth
    Sell the Bose setup and start over.
    Bose isn't what it's cracked up to be.
  5. Albon Audiophyte
    Albon
    Aug 24, 2009
    6
    1
    What do u mean Isiberian?
  6. lsiberian Audioholic Overlord
    lsiberian
    Nov 17, 2008
    12,238
    3,167
    hell no
    Don't buy anything right now until we help you get your head straightened out.
    1. Bose stinks this fact is universal in every audio forum on the internet.
    2. Cables should be cheap.(this one gets a lot of folks) Monoprice.com is the best source for cables. Blue Jeans Cable is the next best.
    3. Speakers are the most important part of a system they make the sound.
    4. Receivers should ideally be 20% of your budget but certainly no more than 40%. Also never buy a receiver for it's power rating. Buy from a reputable brand. Denon, Onkyo, Pioneer, Yamaha, HK, Marantz are all reputable brands. Sony isn't for receivers.
    5. Starting simple and adding on net's a better setup than getting everything at once.
    If you want a small speaker setup then look for a KEF 2001 set. Pair them with an Onkyo 606 and you're set with a nice setup.
    If you want a great sounding setup and don't care about speaker size. Then let's talk.
  7. markw Audioholic Overlord
    markw
    Nov 26, 2003
    11,235
    3,051
    Joisey and Texas
    Not to gratiously knock bose, but...
    ...any $200 - $300 entry level receiver you can buy will provide you with enough power to allow those speakers to deliver all they are capable of, and then some. Anything more than that is throwing good money after bad.
    Unless you're absolutely in love with their styling, then I would strongly suggest you let the group here help you. You can get a LOT better bang for the buck with not much sacrifice in size.
    But hey, it's your money.
  8. lsiberian Audioholic Overlord
    lsiberian
    Nov 17, 2008
    12,238
    3,167
    Bose systems have very little bass and very poor response. They cost way too much and are cheaply made. As a speaker builder I can tell you that my recession buster kit speakers have more cost in them than a bose speaker. Physics can't be defeated. Good speaker design is a science not an art.
    http://www.intellexual.net/bose.html
    Any other speaker designer/builder would be happy to join me in condemning these speakers.
    Trust me here friend. Bose= Better Off Somewhere Elses
  9. Albon Audiophyte
    Albon
    Aug 24, 2009
    6
    1
    Let's talk. I don't have a LOT of room but I don't really care about the size of the speakers. It's a big room (living room, dining room and kitchen in the same area). I have room on each side of my couch and about 15" on each side of my 56" DLP Samsung. But I could use this space for the subwoofers and the amp. My budget is arround 1500-2000$ tax in CND. I'm gonna use this setup mostly for blurays and XBOX 360/PS3. Would be nice if the setup sound great with music also.
    Thanks guys for you time I appreciate!
    Phil
    • Like Like x 1
  10. chris357 Senior Audioholic
    chris357
    Jul 1, 2009
    606
    124
    Wauconda IL
    you score 1000 points for asking before you bought !! :D
    • Like Like x 1
  11. MatthewB. Audioholic General
    MatthewB.
    Nov 7, 2008
    1,354
    480
    My Own Private Hell
    Albon, I agree Bose makes shytty speakers (but are great at advertising and convincing hoity toity uber snobs that they are the best) Seriosuly there "bass module" can only get down to 55Hz (which any decent bookshelf speaker can accomplish without a sub) the frequency response range of the sats and the bass module lack a lot of the frequency range.
    I have an old copy of "Sound and Vision" April 1999 (page 52-53 where they review the Bose Acoustimass 15 system the bass module only could muster 46Hz - 202 Hz and the speakers 280Hz - 13.3kHz (most speakers can easily acheive 100hz - 20kHz, but what this article does show is that on a typical 20Hz-20Khz scale you are missing 20Hz-45Hz then 203-279hz and 13.4-20kHz. I don't know about you but if I'm spending 2,000 on speakers they better achieve the full frequency response.
    Here's a great qoute from the article. The figure given in the table is for the worst case result, which was for the front left/right satallites. Their response fell off rapidly below 300Hz and a 3-db peak appeared between 2 and 4 kHz, plus a 13-kHz treble peak and a related notch.
    Which is saying that this speaker failed miserably in the frequency range that most people are prone to hear. Hence the term, no highs no lows must be Bose.
    For 2,000 I would seriously look at the 7.1 SVS system which has an incredible sub and speakers that would easily beat out the Bose and fit within your space constraints.
  12. majorloser Moderator
    majorloser
    Aug 7, 2005
    7,034
    3,218
    Florida aka: Hurricane Central
    It might just be me, but I smell something....
  13. romantic Junior Audioholic
    romantic
    May 2, 2009
    61
    1
    Vancouver, BC
    If you haven't bought it yet, you are lucky and it's time for you to start looking for a real system. If you did, dont panic. It's not the end of the world; however, you have to consider whether you want to keep it or not. You can keep using it for a while until you can get a new system. Any entry level receiver will be fine. Or you can cut lost now and get the better sound system.
    PS. I used Acoustimass before I went to the audio store and listen to the real sound system. You can try this as well before making any decision.
    Hope this help
  14. JerryLove Audioholic Samurai
    JerryLove
    Jul 17, 2008
    2,219
    601
    Tampa, FL
    So if I understand, you've got your sources (PS3 etc) and your display already.
    Simple enough: find out what speakers interest you in about 80% of your budget. Make note of the required wattage (likely in the 100W range). Go find the least expensive receiver with every feature you need (HDMI 1.3a switching? HD-Radio? Whatever your requirements are) and enough wattage to drive y our speakers... but make sure it's a reputable receiver (Marantz, Pioneer, Denon, etc). Just search Audioholics for a review of the unit or a related unit.
    Once you've picked the receiver to power the range of speakers you are likely to use: start auditioning ones in your remaining budget.
    If you end up finding something you love with an unusual wattage requirement (most planar speakers come to mind) remember that it will drive up your amp costs.
    Have fun. Audioholics is full of threads and articles on "best speakers" in a given price; and there are a lot in that $1k-$1.7k range you are spending.
    PS. There's an entire sticky on Bose on this forum. You might want to read the first page.
  15. Albon Audiophyte
    Albon
    Aug 24, 2009
    6
    1
    Thanks a lot for ur anwser guys. Very helpful. Now that my choice stopped on the AVR-790 or the VX-1019, I have to find some decent speaker/sub. If you guys have any suggestion or link on this forum I would appreciate!
    And yes I have my sources (Display, 360, PS3...). I just need the sound! ;)
    Thanks again!
Share This Page
  • CEDIA
