SV Sound PB-12NSD Subwoofer Preview
Discussion in 'Subwoofers' started by admin, Nov 29, 2011.
  1. admin Audioholics Robot Staff Member
    admin
    Apr 16, 2004
    172
    1,617
    The new SVS PB-12NSD subwoofer features a custom designed 12" aluminum cone driver with a 4" flared port and 400 watt continuous rated power amplifier. It maintains a relatively compact form factor (at least as far as big box subwoofers go) with true 20Hz extension. Utilizing a high quality drive unit with a meaty amplifier in an inert and soundly engineered enclosure, the PB-12NSD offers a level of performance not typically found at this price point. This preview article gives a glimpse of the PB-12NSD performance capabilities with real CEA 2010 measurement data. We look forward to conducting a formal review of what we feel will be the subwoofer to beat in the under $1k price category.
    [​IMG]
    Discuss "SV Sound PB-12NSD Subwoofer Preview" here. Read the article.
    • Like Like x 2
  2. homwerk Audioholic Intern
    homwerk
    Feb 1, 2010
    28
    0
    Awesome!!! Thanks for including preliminary test data in the preview. I am close to buying a new sub for my HT setup and was waiting to see how this would stack against the LFM-1 EX. Now if we can only get you guys to test an FV12 :)
  3. GlocksRock Audioholic Spartan
    GlocksRock
    Oct 28, 2005
    6,196
    946
    Charlotte, NC
    Looks awesome, can't wait to see the full review.
  4. cel4145 Audioholic
    cel4145
    Nov 29, 2011
    198
    26
    FYI: the table caption says "Max Output Mode – all ports open," yet the listing for the EX figures appear to be the one port open extended mode. The EX would look even more favorable from 25hz on up if the max output mode figures had been listed.
    Meanwhile, I look forward to reading the full review :)
    • Like Like x 1
  5. homwerk Audioholic Intern
    homwerk
    Feb 1, 2010
    28
    0
    Good catch, Cel! Wouldn't that mean that the EX would look less impressive down to 20hz and below though?
  6. gene Audioholics Master Chief Administrator
    gene
    Jul 1, 2002
    7,979
    3,487
    Florida
    You're right, I mistakenly posted the 18Hz tune mode data for the Outlaw. I went back and updated the article with the 25Hz data. The SVS PB-12NSD now has a +3.5dB advantage at 20Hz but the Outlaw LFM-1EX has about a +4dB advantage above 40Hz.
    gene,
  7. billy p Audioholic Ninja
    billy p
    Apr 14, 2006
    3,698
    1,222
    The numbers posted don't appear to represent what Svs previosuly released in their CEDA data for the pb12 nsd? Going back and forth from one thread to another there appears to be some confusion...at least to me.
    Here are ED's numbers>
    10/NA/NA/Insufficient SNR
    12.5/89.1/15.2/Limited by 3rd Order Harmonic
    16/99.0/19.0/Limited by 3rd Order Harmonic
    20/107.5/10.4/Amp Limited
    25/110.3/12.1/Amp Limited
    31.5/111.4/6.3/Amp Limited
    40/111.9/6.9/Amp Limited
    50/112.0/3.6/Amp Limited
    63/112.3/3.5/Amp Limited
    80/112.8/3.4/Amp Limited
    yet in the preview article of the same sub the numbers look to be about 3dbs short across the entire bandwith?:confused:
    20-104.5
    25-107.3
    32-108.4
    40-108.8
    50-109
    63-109.3
  8. gene Audioholics Master Chief Administrator
    gene
    Jul 1, 2002
    7,979
    3,487
    Florida
    You are comparing Peak (Ed's forum post) to RMS (my Preview article). My Preview article had all SPL's converted to RMS to be more inline with all data Josh Ricci publishes for us. It's also clearly noted in the article. I know this stuff can get confusing which is why I am a stickler for marking everything.
    gene,
    • Like Like x 2
  9. kini Junior Audioholic
    kini
    Nov 30, 2011
    88
    14
    Any idea how the Axiom EP350 would compare? Similar specs (on paper) and for me the EP350 is at least $200 less expensive (free shipping to Hawaii).
    Thanks
    kini,
  10. lsiberian Audioholic Overlord
    lsiberian
    Nov 17, 2008
    12,238
    3,167
    On A Bridge in Fort Worth
    It certainly fills the bill for bass. These lower price offerings are just getting better.
  11. trolly Enthusiast
    trolly
    Jan 11, 2009
    10
    10
    I recently tried both the new PB12-nsd and the Axiom EP500 and the NSD easily outperformed the Axiom (IMHO).
    • Like Like x 2
  12. gene Audioholics Master Chief Administrator
    gene
    Jul 1, 2002
    7,979
    3,487
    Florida
    I don't doubt that since the Axiom implements a brickwall HPF which raises group delay near tuning and also negates and room gain at very low frequencies where the SVS still produces usable tactile bass that couples with the room.
    gene,
    • Like Like x 1
  13. gtpsuper24 Full Audioholic
    gtpsuper24
    Aug 28, 2011
    313
    85
    Ohio
    Axiom EP500 seemed to perform really well last year in the AH test.
    Axiom Audio EP500 Subwoofer Review — Reviews and News from Audioholics
    Incredible depth and slam
    Oodles of output
    Very musical
    Balanced Inputs
    Is the new PB12 NSD that much better?
    "The EP500 is one truly powerful subwoofer, capable of very high SPL levels, especially in smaller rooms. We recommend securing any expensive china or knickknacks before firing this bad boy up for the first time. Due to its very linear low frequency extension, output capabilities, and EQ options, the less fussy placement nature of this subwoofer is quite invaluable."
  14. gene Audioholics Master Chief Administrator
    gene
    Jul 1, 2002
    7,979
    3,487
    Florida
    That review of the EP500 was from 2004! The date doesn't reflect that since we've updated our CMS system and it messed up the dates on most of our older articles.
    That being said, converting my 1 meter rms 4pi to 2 meter GP for the Axiom EP500 yields:
    20Hz 87dB
    25Hz 97dB
    30Hz 99dB
    vs the SVS PB-12NSD CEA #s 2 meter rms GP:
    20Hz 104.5 dB
    25Hz 107.3 dB
    30Hz 108.4dB
    although reverse sine sweeps vs CEA tests produce slightly different results, they usually correlate where the sub is driver limited not amp limited which is the case below 30Hz for both subs.
    That being said, yes the new SVS sub appears to have quite a substantial output advantage over the Axiom EP500v1 at least. We haven't tested the V3 version but can't imagine the differences would narrow this performance gap much at all. Axiom doesn't ship review samples to reviewers to measure their subs via Groudplane or CEA testing so we will likely never know.
    gene,
  15. gtpsuper24 Full Audioholic
    gtpsuper24
    Aug 28, 2011
    313
    85
    Ohio
    Ok I seen the article dated last year Aug 2010. Tried to figure out what changed in a year.
  16. zhimbo Audioholic General
    zhimbo
    Mar 2, 2007
    1,117
    328
    Ann Arbor, MI
    On equiprment reviews, look for the Review Date, not the "last modified" date. It's there under the ratings, before the pro/cons.
    • Like Like x 1
  17. gtpsuper24 Full Audioholic
    gtpsuper24
    Aug 28, 2011
    313
    85
    Ohio
    Thanks, I didn't see it listed just seen the Aug 25, 2010 date. Which I though was weird cause I didn't remember Axiom having a sub tested recently.
    I just stumbled across it googling, cause I posted on Axioms forum in a response to someone asking about the SVS Ultra vs the EP800 or SubM. I posted that Axiom's subs are poor performers and don't offer the bang for the buck like other brands do, and the designs are dated.
    I said "for the price Axiom subs suck" and that started a debate so I just was looking for some reviews.
  18. gene Audioholics Master Chief Administrator
    gene
    Jul 1, 2002
    7,979
    3,487
    Florida
    Axiom subs don't suck. The EP500 IMO is their best performer/dollar for a variety of reasons. However, the rest of the sub world has really evolved in the last 4-5 years and are offering a LOT more performance for less money. It still doesn't mean their subs "suck", it just means they aren't as high value as they used to be b/c the rest of the competition got that much better.
    This is probably the most detailed test report you can find on the EP600v2:
    http://www.hometheatershack.com/forums/subwoofer-tests-archived/973-axiom-ep-600-2nd-test.html
    It shows its a good overall performer but rather pricey and a large box for its hohum output below 30Hz.
    gene,
  19. gtpsuper24 Full Audioholic
    gtpsuper24
    Aug 28, 2011
    313
    85
    Ohio
    Thats almost 6yrs ago. Axiom has increased their prices but have done no significant improvements. What can $1860 get you today?
    How would you compare the new HSU VTF 15H or PB 12+ to the EP600? Both of those are much cheaper or better yet the PC13 Ultra is $200 or so cheaper too?
    I read on Axioms forum someone said the EP600 isn't worth it cause of the big hollow cabinet and no bracing, and the Axiomites said they love the distortion from that cause it add warmth to the sound? :confused:
  20. gene Audioholics Master Chief Administrator
    gene
    Jul 1, 2002
    7,979
    3,487
    Florida
    The HSU VTF-15H is an incredible value that didn't exist 6 years ago. It's also quite a large box. The PB-12Plus DSP is an engineering marvel IMO. It also didn't exist like it does today, 6 years ago.
    gene,
Share This Page
  • CEDIA
