<font color='#000000'>Zumbo,
First off, you must realize and identify the differences between bi-amping and bi-wiring. A major and noticeable improvement in sound quaity can be attained via bi-amping. Bi-wiring on the otherhand, has been debated and argued extensively throughout the online forums. Esentially all you are doing by using both main A and B speaker terminals per speaker is to simpify the bi-wire issue of cramming a buch of copper into one set of speaker jacks, banana plugs, etc. Theoretically speaking, bi-wiring adds more copper between amp and speaker, but increasing the gauge of a single wire does the exact same thing.
"So if you hook-up two sets of fronts, using A & B, would the two sets of speakers share the power? I was under the impression that there was seperate power for speakers A & B."
Yes they share the same power. No, there is only one transformer inside of the unit generating power. If you want to play two seperate speakers at equal volume's "independently" from each other, then you'll have to set your receiver to 5.1 mode and re-assign the two remaining channels to power a Zone 2. So basically, you could have the main A speakers playing in 2-channel stereo concurrently with another seperate pair in 2-channel also.
If you are not noticing any difference between the 8 and 6 ohm switch position it is because you are not "cranking" it loud or long enough for the protection scheme to kick in. If this is the case, the leave it set to 6ohm. If you want increased output above your current listening, then bump it up to 8ohm, but not quite loud enough to push the unit into shut-down mode. Be sure to have plenty of venthilation and air circulation around the unit.</font>
