Safe and Sound insulation
Discussion in 'Room Acoustics, System Layout & Setup' started by MoreDakka, Jan 29, 2008.
  1. MoreDakka Enthusiast
    MoreDakka
    Jan 21, 2008
    14
    0
    I'm not sure what affect this will have on the room itself, has anyone used this product while constructing their HT and how well does it perform for dampening the sound to other levels and does it make a difference on the quality of the sound for your HT?
    Thanks.
  2. Rickster71 Audioholic Spartan
    Rickster71
    Jan 15, 2006
    7,154
    4,482
    N.J.
    Keep in mind, there is much more to sound deadening; not just the insulation.
    Mineral wool, or ( Rotten Cotton, as it's called in the trades) is very good, and quite common in commercial construction.
    It's has much more density than fiberglass.
    I would shop mineral wool by price, not necessarily by brand name.
    Safe N Sound is just a brand name.
  3. Glenn Kuras Full Audioholic
    Glenn Kuras
    Jun 21, 2005
    291
    48
    Right on the money, infact I would go with mineral wool of Safe N Sound. Much cheaper and works just as well.
    Glenn
  4. MoreDakka Enthusiast
    MoreDakka
    Jan 21, 2008
    14
    0
    Hey thanks for the info about Mineral Wool. I'll have to see if there is a local place where I can buy that. So far all I've found is the Safe and Sound stuff ($32 CDN for 50ish sq/ft).
  5. ParadigmDawg Audioholic Overlord
    ParadigmDawg
    Nov 20, 2006
    10,366
    3,215
    Hiding from Alex
    Just see if one of these are close to you.
    http://www.spi-co.com/index.html
  6. MoreDakka Enthusiast
    MoreDakka
    Jan 21, 2008
    14
    0
    :( Doesn't look like they like Canada :(
  7. ChrisSovari Enthusiast
    ChrisSovari
    Jan 30, 2008
    20
    2
    The Roxul Safe'n'Sound - Noise & Fire say's "Roxul Safe 'n' Soundâ„¢ is made from non-combustible mineral wool so it does not burn and will not release any toxic gases.". I am not able to post the link so check their website.
Share This Page
  • CEDIA
