RBH Sound SX-61/R Bookshelf Speakers Video Review
Discussion in 'Loudspeakers' started by admin, Oct 21, 2011.
  1. admin Audioholics Robot Staff Member
    admin
    Apr 16, 2004
    172
    1,617
    Sometimes we get caught up in the specs and features of products - in fact, that's often the most stand-out thing about some of the things we review. When we fired up the RBH Sound SX-61/R Reference Bookshelf speakers, all that went out the proverbial window. For the next two hours we didn't do anything but shuffle in and out various discs and tracks and listen. And I mean "lose ourselves in the moment" listening. The SX-61/R's have that signature RBH Sound midrange that let's you hear things you just don't with most bookshelf systems. The speakers just dissolve into the room and you can detect every nuance in the music. Things like a snare drum played with brushes just become ear candy and kick drums reveal that decisive snap at the top. You can listen for hours and not get tired.
    [​IMG]
    Discuss "RBH Sound SX-61/R Bookshelf Speakers Video Review" here. Read the article.
  2. TheWarrior Audioholic Field Marshall
    TheWarrior
    Sep 22, 2011
    1,809
    406
    GA
    Wow, no responses?
    Ok, I've got a lovely set of WM-30's... would these or even the decimos provide a true night and day difference?
  3. gene Audioholics Master Chief Administrator
    gene
    Jul 1, 2002
    8,024
    3,511
    Florida
    While the W30s are a nice on-wall speaker, they aren't even in the league of an MC bookshelf speaker from RBH let alone the SX-R or Decimo products. Yes there is a huge difference in terms of imaging, clarity most notably in the top octaves and depth of soundstage. The WM-30s are competitive to the Axiom on-wall products which I believe I directly compared in my review.
    It's not really fair to compare an on-wall speaker to a dedicated bookshelf. Different application and associated trade offs in performance for the on-wall product.
    See: http://www.audioholics.com/reviews/speakers/architectural/emp-ew30
    gene,
  4. TheWarrior Audioholic Field Marshall
    TheWarrior
    Sep 22, 2011
    1,809
    406
    GA
    Thanks Gene, I was hoping you'd see this!
    The WM's are by far the nicest speakers I've owned and my upgrades have been a steady incline in quality. As I understand it, this would be a giant leap. I lack experience but I do have a nice small space, with a max speaker width being 6 ft, and listening distance of 7 feet. And an appetite (and wallet) to continue my sound education. Not to mention several years of reading this site.
    Should I make the switch, I understand in the reviews that the speakers need a fair bit of adjusting to sound their best. The shelf they will sit on will be fabricated by me, and the speakers would flank a plasma screen. The electronics powering the speakers would be bought specifically for the speakers as well.
    Any words of caution, recommendation, or suggestion in undertaking this project? And yes I will be happy to publish a full report on the site :)
  5. gene Audioholics Master Chief Administrator
    gene
    Jul 1, 2002
    8,024
    3,511
    Florida
    If you plan on placing the RBH bookshelf speakers on a wall, realize they are rear ported. You will likely want to plug the ports in that case which will limit the bass output a bit as a result. These speakers really would work best on stands but I managed to integrate the Decimo version on a cabinet shelf in my Family Room system. I also run mine crossed over at 80Hz.
    You should really consider investing in a sub to mate with them if you go down this route. The RBH SX-12 would go perfectly with these speakers but you also want to consider feeding them some good power. Emotiva makes really good amps for the money. An Emotiva UPA-2 or XPA-2 would be great for them or if you're doing 5.7/7.1, consider an XPA-5 and a good AVR to power the back channels.
    gene,
    • Like Like x 1
  6. TheWarrior Audioholic Field Marshall
    TheWarrior
    Sep 22, 2011
    1,809
    406
    GA
    Already planned on an XPA-2. I think I'll enjoy them in a stereo configuration for a while before adding, and probably nab the XMC when it comes out, hopefully no later than January.
    I anticipated using the port plugs. However, if I were to extend the shelf a bit, what is the minimum space needed for the ports to be effective? Do inches matter, or am I SOL because feet are needed? Brick is what the wall is made from, but I can put any material over it as well.
    Thank you for your feedback!
  7. gene Audioholics Master Chief Administrator
    gene
    Jul 1, 2002
    8,024
    3,511
    Florida
    If you allow at least 2-3 inches you should be fine. If the bass is too boomy, just plug em.
    gene,
  8. puckhead Audioholic Intern
    puckhead
    May 6, 2009
    32
    7
    How would these compare to the RBH 61-SE/R and to the Decimos -- what are the main differences between them? How much better are the Decimos?
  9. TheWarrior Audioholic Field Marshall
    TheWarrior
    Sep 22, 2011
    1,809
    406
    GA
    The Decimo's have a fiber resin cabinet, an upgraded Scan Speak tweeter and crossover.
    If you're in the market, RBH's are absolutely top notch. If you're totally obsessed and want a limited run speaker while its still available, grab a set of Decimo's.
    Personally, I have backed off as my living situation just is not allowing me to enjoy such excellent speakers at volumes that make them worth the expense. The money has been set aside for full range towers in a few years when I build my house :)
    • Like Like x 1
  10. gene Audioholics Master Chief Administrator
    gene
    Jul 1, 2002
    8,024
    3,511
    Florida
    The Decimo's have a slightly upgraded Xover but all 3 speakers use the same drivers. The Decimo's have the most inert cabinet and smoothest front baffle of the 3. I directly compared the Decimo's to the 61-SE/R as I used to own a set of the latter speakers. They are very close, but the top end of the Decimo's just make you melt. The imaging is slightly better and the bass is a bit snappier on the Decimo's. It's not night / day difference, but the cabinet does make a difference. The new SX-61/R should be very similar in performance to the Signature Reference version.
    gene,
    • Like Like x 1
  11. scattershot Audioholic
    scattershot
    Aug 12, 2009
    109
    14
    In the interest of helping out any potential RBH buyers of these speakers out I wanted to point out some related resources on Audioholics:
    RBH Signature Classic Reference Series 61-SE/R [MSRP: $2700 / pair]
    Product Website:
    RBH 61-SE/R Bookshelf Speaker
    Related Review:
    Status Acoustics Decimo Review | Audioholics
    RBH Signature SX Reference Series SX-61/R: [MSRP: $1900 / pair]
    Product Website:
    Bookshelf: RBH SX-61/R Bookshelf Speaker
    Review:
    RBH Sound SX-61/R Bookshelf Speakers Review | Audioholics
    Video Review:
    https://www.youtube.com/watch?v=FZUtYMQ29FI&feature=player_embedded
    Forum Thread (e.g. this thread!)
    http://forums.audioholics.com/forum...-sx-61-r-bookshelf-speakers-video-review.html
    Puckhead asked in this very thread "How would these compare to the RBH 61-SE/R and to the Decimos -- what are the main differences between them? How much better are the Decimos?"
    Gene said:
    "The Decimo's have a slightly upgraded Xover but all 3 speakers use the same drivers. The Decimo's have the most inert cabinet and smoothest front baffle of the 3. I directly compared the Decimo's to the 61-SE/R as I used to own a set of the latter speakers. They are very close, but the top end of the Decimo's just make you melt. The imaging is slightly better and the bass is a bit snappier on the Decimo's. It's not night / day difference, but the cabinet does make a difference. The new SX-61/R should be very similar in performance to the Signature Reference version.[61-SE/R]"
    Lastly, the new Status Acoustics (premium RBH speakers) that replace the Decimo’s are out.
    Status Acoustics Decimos Bookshelf Speakers:
    Status Acoustics Decimos Bookshelf Speakers: [MSRP: $12,000 / pair]
    Product Website:
    Status Acoustics Products--Voce Fina
    Review:
    Status Acoustics Voce Fina Bookshelf Speaker Review | Audioholics
    Video Review:
    Status Acoustics Voce Fina Bookshelf Speaker CEDIA 2013 Coverage - YouTube
    Forum Thread:
    (I hope the above info can save Gene and others time from having to answer repeated queries that are similar)
  12. scattershot Audioholic
    scattershot
    Aug 12, 2009
    109
    14
    Just an fyi guys.
    Gene from Audioholics mentioned that with respect to the discontinued Status Acoustics Decimo speakers (MSRP: $2900)
    "the 61-LSE's had the upgraded Status drivers and crossover components."
    (The 61-LSE were only offered for a limited time and are now discontinued).
    "Now you have to step up to the new Status Voce Fina Granite speakers to get those crossovers along with the Beryllium Driver:"
    Lastly Gene added "The SX-61/R and 61-SE/R have the Status drivers but standard RBH crossovers."
    Hope this info may prove helpful to some other readers who are looking at purchasing one of the highest-quality RBH bookshelfs.
  13. AcuDefTechGuy Seriously, I have no life.
    Jul 10, 2007
    20,170
    4,395
    Oklahoma City
    So is Status Acoustics the flagship line of RBH?
    IOW, Status Acoustics > RBH Reference > RBH Signature > RBH MC > EMP ?
  14. nova Full Audioholic
    nova
    Jul 7, 2004
    257
    8
    Northern Utah
    nova,
Share This Page
  • CEDIA
