Did it just stop playing in those speakers? Other speakers played fine?
Did it give you any blinking lights or error codes?
Multi-channel stereo is particularly difficult for AVRs, and the more speakers you at (9!), the tougher it is going to be on the power supply of that AVR.
What happens if you try it with a much lower volume level? I really suspect that you are exceeding the capabilities of your AVR, and if you keep that up you will damage your AVR.
It may help to know what speakers you are running and what the nominal impedance rating is for your speakers.
