OK, the living room is 11.5' wide. So, the 25% distance point from each wall is 45". That raises a question. Is that 25% point supposed to be the centre of the driver? Centre of the port? Or, half-way between the driver and the port? Does the port location have any bearing on it?
The problem is the location closest to the outer wall. At that point, the height from the ceiling to the underside of the rafter is 27.5". The enclosure would have to extend several inches beyond that point, in each direction. At 36" from the wall, the height from ceiling to rafter is 22".
Of course, I could spread the drivers further apart by making the enclosure wider. That would allow me to lower the height proportionally.
On the other side of the room, height isn't a problem, as the roof is well above the height needed. That said, I'd like the enclosures to be of identical dimensions to ensure identical performance.
I don't know if you can understand that description, but what it boils down to, is that the maximum height for the enclosure would be about 20" (that would be at the outside corner, at the lowest part of the roof slope), to give me a fudge factor. The depth would be 13", giving me a port width of 11.5". If I added 9" to the width of each enclosure, for a total of 1.5', that would get me down to about 20" in height. That volume should account for lot's of internal bracing. I could shrink the enclosure somewhat, by using the external bracing.
An expansion in width will be a problem WAF-wise, as it will cover much more ceiling area than originally estimated. I'll have to deal with that...
I don't quite understand that. My idea was to use "T" or "L" type bracing that would overlap at the corners and be attached to each other, as well as the enclosure. The bracing could be massive and from a physics standpoint, would be just as strong as internal bracing. In fact, it would be stronger, because it could be bigger and I could use more of it. I came up with that idea, because the bracing "allowance" from the calculator you sent me was only about .05ft^3. That's just one brace, unless I make them really skinny - then I
might get 2. The braces I have in my attached sketch use up that entire volume.
I just opened the attached sketch.
I didn't realize how fuzzy it was.
Can you read the dimensions? My apologies...
