impedance vs non impedance volume control
Discussion in 'GENERAL AV Discussions' started by chrisp14, Feb 27, 2010.
  1. chrisp14 Audiophyte
    chrisp14
    Feb 27, 2010
    1
    0
    This may be a stupid question, but when you're running a separate powered zone off an AVR with a volume control unit in another room, does it matter if the volume control is impedance-balancing or not??
  2. MDS Audioholic Spartan
    MDS
    Oct 23, 2004
    6,691
    863
    Austin, TX
    Only if you have two or more pairs of speakers wired in parallel. If for example, you were to use the single zone 2 speaker outputs to drive a pair of speakers in the patio and a pair somewhere else you'd need impedance matching volume controls because the two pair wired in parallel will present a 4 ohm load to the receiver (if both pair are 8 ohm).
    MDS,
Share This Page
  • rbhsound.com
  • Emotiva.com
  • CEDIA
