If the software does not instal correctly, the receiver will not work from then on, but stick on a loop. If the BIOS will not re flash at the repair shop, then the unit is never going to work again.
Since the processor is high on the list for failure, then a firmware update, is a bad idea right now. Resetting the receiver to default will not cause this issue, and should be done once before sending it in for service.
The other rule, is never do a firmware update unless you have to. That means that there is a feature you want that does not work, or a significant fault comes to light that there is a definite firmware fix for. With these exceptions you run in the other direction from firmware updates.
