I am still trying to make a final decision about speakers for my new HT system.
I have gotten a lot of great input from forum members about BIC Acoustech and BIC America (Venturi) speakers – and those two systems are still at the top of my list – but I have also been considering other systems where I can get a comparable price – and where I have either read good things in this forum and/or others, or have seen good reviews, etc. I know there is no substitute for hearing speakers in person, but for the BIC’s that’s not possible since they are not sold in retail stores. And I’m not sure of the value of hearing speakers in a showroom that has no relationship whatsoever to my own room. I’m pretty committed to getting them online based on reviews, reputation, recommendations and the best apparent value
My budget is between $500 and $650 for 2 fronts, a center and 2 surrounds. I am pretty well settled on having floor standing mains instead of bookshelves mounted on stands – primarily for aesthetic/WAF reasons. But I am considering one option that doesn’t include floor standing mains – see Option 3 below.
I recently bought a Pioneer VSX-74TXVi receiver (which is really fantastic) and a JBL S120PII subwoofer (12” front firing, long throw, 400 watts RMS) -- which I also think is great. [BTW – my $0.02 – I have seen other comments about this sub that are pretty negative – and being a newbie, maybe I don’t know the difference – but it performs really well for me in my room, and I’m very happy with it so far. Shakes the windows, rattles the walls and punches me in the chest while delivering good crisp bass with deep extension (to my ears anyway) with the gain set to just over 60%.]
My room is pretty large (3,500 cubic ft) and acoustically soft (lots of carpeting, drapes, soft furniture, etc.), but even now I have no problem filling it with a marginal 2.1 system consisting of 2 old Fisher XP-7B floor standing 10" 3-way speakers and the new the JBL sub. Running the Pioneer 74 at -8 dB with just this simple setup is too loud for continuous play – I use that level for major action viewing like the Omaha Beach scene in Saving Private Ryan or the first major battle scene in Master & Commander. But for regular action, dialog, etc. I dial it back to about -15dB and that provides plenty of sound even
without a good set of speakers. My listening is about 80/20 TV & DVD to music.
I am pretty well up to speed on the various differences between the two BIC lines, so don’t really need much more input about them. But I would like to get opinions about how the BIC lines compare to some others – in particular Infinity Beta, Infinity Primus, Polk Audio Monitor and the Polk Audio R Series. In most cases to keep the cost down I have listed a pair of small bookshelfs as “surrounds.” I realize that they are not designed as true surround speakers, but I’m willing to sacrifice here to get a better front sound stage – and then upgrade the surrounds later if the bookshelfs are inadequate.
Note: All costs shown do not include shipping.
Option 1 BIC Acoustech Cost = $600
HT-75 L/R Mains
HT-65 Center
HT-63 Surrounds
Option 2 BIC America w/floor mains Cost = $455
DV-64 L/R Mains
DV-62CLR Center
DV-62Si Surrounds
Option 2A BIC America w/Frias “extensive mods” Cost = $810
Same as Option 2 but with Ed Frias’ “extensive mods”
For this option I would buy the speakers directly from Ed
with not only his X-over mods, but the speakers would
be acoustically matched by Ed, have higher quality
components in the X-over, etc.
$810 is more than my budget, so I would probably substitute DV-52Si’s w/o the
mods for the surrounds. This brings the cost down to $645
Option 3 BIC America w/o floors and w/Frias mods Cost = $595
DV-62CLR -- 3 for the entire front soundstage L/R/Center – highly recommended by Ed Frias
DV-62Si Surrounds
Buy the 3 DV-62CLR’s from Ed Frias w/”extensive mods”
Buy the DV-62Si’s w/o mods
Using 3 DV-62CLR’s for the front soundstage seems like a great idea, but
I’m not sure how I would mount the DV-62 CLR’s on stands and how they would look.
Any ideas/input on how to mount center speakers like the 62CLR’s vertically on stands
without being top heavy and looking weird would be welcomed.
Option 4 Infinity Beta Cost = $810
Beta 40 L/R Mains
Beta C250 Center
Beta 10 Surrounds
This is more than my budget, so maybe I would probably substitute BIC DV-52Si’s for the Beta
surrounds. This brings the cost down to $655 – the top end of my budget.
Option 5 Infinity Primus Cost = $500
Primus 360 L/R Mains
Primus C25 Center
Primus 150 Surrounds
Vann’s has these at a fantastic pre-order price – but I’m not sure when I would get them.
Also – I assume they are not as good as the Beta’s – but the price seems great.
Option 6 Polk Audio Monitor Cost = $725
Monitor 60 L/R Mains
CS1 Center
Monitor 30 Surrounds
This is more than my budget, but I can get the Monitor 60’s for just $450
a pair and it seems too good to pass up.
BTW -- Does it make sense to substitute the BIC DV-62CLR for the center with non-BIC mains?
I know it’s a different manufacturer, but since the BIC 62CLR is so highly rated it seems a shame to get any other center that costs more and isn’t as good.
Option 7 Polk Audio R50 Mains Cost = $675
R50 L/R Mains
--- These are in an auction that ends in a few hours so may not be able to get this price again
CS1 Center
R15 Surrounds
Option 8 Polk Audio R30 Mains Cost = $450
R30 L/R Mains
CS1 Center
R15 Surrounds
Could spend some extra and get the CS2 center for total cost = $510
I have not listed Klipsch as an option because I have seen many posts here and elsewhere saying that the BIC Acoustech’s are just as good (or almost as good, anyway) for a lot less $$. I’m sure there is disagreement with this, but a reasonable level of quality speakers from Klipsch would be well outside my budget, anyway.
Sorry for the long post, but you guys are the best
and I know you’ll give me some great feedback.
Thanks in advance…….
