If an MTM center channel measures +-1db on axis and +- 3db off axis up to 30 degrees then I would say that it is a well designed speaker/crossover.
No speaker is perfect, no setup is perfect, and people need to get the best that they can within their respective budgets and setups. MTM's are a perfectly viable way of creating a truly excellent center channel. Are there better ways? Yes, both horizontally and vertically, there are better ways. Can an MTM fulfill the criteria that I added to your post? Most definitely.
If an MTM can measure +- 1/2 db on axis and +- 3db up to 30-45 degrees off axis and that covers your entire seating area, then with RC further improving performance, why would you need anything more than that? Why pay hundreds or thousands more, adjust your entire setup for something you don't need or that would get you improvements that may or may not be audible?
Also, you admit that an MTM can sound and measure well off axis. So it sounds to me you're arguing about the the design, and your distaste for it, rather than what it can actually do.
I have to admit that excellent off axis response up to 30 degrees is a higher number than I have ever come into. If you meant 15 degrees each way, for a total of 30 in that sense, okay then. I'm not saying you aren't correct! It's just higher than I've yet read about. I usually see something on the order of trying to remain under 20 degrees. When last using a horiz MTM, I was told by someone when considering its xover point and driver spacing, that the mids were 180 out of phase at about 20 degrees.
That said, I think 20 degrees really is quite a bit more than people might expect it to be; I think a great majority of setups have viewers within 20 degrees, or at the very least, definitely for at least the first few or several viewers (before you start bringing in seats from other rooms or something).
As I understand it, a better off axis performing one would have a lower xover point, with closer spaced mids. I suppose as the drivers got closer and closer, the tweeter would be forced to be nestled in the little space above, but then the problem becomes a taller speaker, which undoubtedly would make it either a tight or impossible fit for many cases, which would kill sales.
I would love to see some of the resident speaker experts try to create the "awesomest horiz MTM" (even if one or two of them would have an issue with the word awesome combined with horiz MTM) with two limits: certain budget, and certain height.
We'll just give them great liberty for depth and width (even though that could pose an issue for a fewer amount of people).
Hm, did the OP mention a budget limit, or height limit?
Well, it's your opinion vs Dr. Joseph D'Appolito, and you've stated some strong, controversial, opinions, several times before. Surprised?
Hm, but wasn't the intention of the design to be specifically vertical in this case? Besides horiz dispersion goals, having them vertically oriented reduces floor/ceiling bounce. However good they are at eliminating bounce, well I imagine that must also mean how bad they are at horiz dispersion when oriented horizontally? Just a dumb guess though.
Joseph D'Appolito - Wikipedia, the free encyclopedia
