ColoradoJohn
I'm pulling wire to get ready for my new receiver, and have a question about zone 2.
The VSX-94TXH has a source output for zone 2 (I would like to keep the powered outputs for 7.1). I have a couple of mediocre speakers for the back patio, but need an amp to power them. The speakers are 8 Ohm, 70W Max. Any amplifier suggestions? Also, what is typical for remote volume control?
I have several car amps and a 12 volt power supply. Is this a possibility, or nutty?
OttoMatic
OttoMatic
Hi ColoradoJohn,
I use an old receiver to power my second zone. I have no idea how much power it provides. Unless you plan on playing those speakers really loud, it won't matter much. You can find an old receiver, amp or integrated amp on eBay or AudiogoN for well under $100 (think I paid $30 +shipping). It's hidden in the basement, and I never see it or touch it.
As for volume control, I have to means. First, I use the Harmony 890 RF-based remote, which allows me to control my preamp throughout the house, as well as outside. Second, I have a simple in-line volume control from RadioShack ($30) mounted on the patio. That allows me to control volume on the spot if I don't have the remote.
The car amp idea is a fine one, in general. You'll just need to be sure that your power supply can source enough current for the amp to run at the levels you need.
Good luck.
ColoradoJohn
Thanks Otto.
No, it won't be really loud. Just quiet music when outside eating dinner, playing cards, etc. We usually drag out the boom box, but that won't be needed anymore.
jcPanny
jcPanny
Stereo amp.
Look for a small stereo amp like Audiosource to power the zone 2. It will be more convenient and comparable cost to a 12V power supply with enough power to run the car amp.
The zone 2 feature on most receivers works with analog sources so you will probably need a couple extra analog cables from your source components to the receiver.
ColoradoJohn
You're right. For under $100, the AMP100 looks perfect...
Thanks!
