Now that they have the firmware worked out I have no problem recommending my Zidoo H6 Pro. I put together a Nvidia Shield a friend bought. Personally I like my Zidoo H6 Pro better. It's also cheaper then the Shield.
The sound is excellent and the picture and colors are superb.
One reason, it's easier to work with and less complicated then the Shield. The DDR4 makes it very fast.
Specs are good and the firmware is finally upgraded to work quite well.
Android 7.0 TV Box Zidoo H6 Pro Media Player Quad-Core 2G/16G Dual Band WiFi HDMI 2.0a 4K H.265 UHD 1000Mbps
OS Android 7.0
CPU AllWinner H6 Quad-core ARM Cortex TM -A53 Processor up to 1.8GHZ
GPU Mali-T720MP2
Memory 2GB
Internal Storage 16GB eMMC
Wifi Connectivity 802.11AC WIFI
Ethernet 1*RJ-45 Ethernet Jack (10/100/1000Mbps)
Bluetooth Bluetooth 4.1
HDMI Out Standard HDMI 2.0a@60hz
Video decode HDR10 and HLG video processing
H265/HEVC Main/Main10 profile@Level5.2 High-tier ;4K@60fps, up to 6Kx4K@30fps
H264/AVC BP/MP/HP@level5.1, MVC, 4K@30fps
VP9,Profile 0/2, 4K@30fps
VP6/VP8, 1080P@60fps
MPEG1/MPEG2 SP@ML, MP@HL, 1080P@60fps
MPEG4 SP@level 0~3, ASP@level 0~5, GMC, short header format, 1080P@60fps
AVS+/AVS JIZHUN profile@level 6.0, 1080P@60fps
VC-1 SP@ML, MP@HL, AP@level 0~3, 1080P@60fps
Supports Frame Buffer Compression(FBC)
Output pixel format configurable,YUV420/YV12/NV12/...
Audio decode MP3/WMA/AAC/WAV/AC3/OGG/FLAC/APE
USB 1 * USB3.0
2 * USB2.0
Power DC 5V/2A
other interface 1 * TF card reader SD card interface . Support 1GB/2GB/4GB/8GB/16GB/32GB
1 * IR receiver
1 * AV OUT Composite video and audio port (Cvbs output)
1 * OPTICAL (2CH, 5.1CH)
What's in the box: 1 * TV box
1 * Bluetooth Remote control
1 * HDMI cable
1 * Power adapter
1 * User manual
Perfect Configuration: Based on Android 7.0,Powered by Quad-core ARM Cortex TM-A53, 2G/16G make big games run more smoothly,802.11ac dual-band WIFI,1000M network interface carefreely shows in front of audience with 10 times speed through current mainstream 100M ,without any pressure limit.
Fantastic ZIUI: ZIUI is based on android system,you can have simple APP management,easily find video music pictures file and no need exchange from different APP,support setting passcode of any APP.
For Watching: ZIDOO H6 Pro offers 4K*2K H.265 Hardware Decoding UHD video playback,support 4K@60fps HD Audio(7.1CH) passthrough,24P frame rate auto switch,support hardware decoding,Support BD iso,BDMV,BD rip,BD 3D MVC format playback on video player.
RC & IR Shortcut: Through ZIDOO RC,you can use your favorite operating way to control H6 Pro with your cell phone.The new smart IR remote with progrmmable keys offers a great easy way to control not only the H6 Pro but also the TV at your home,It also supports three programmable color-keys that customizes to open apps quickly.
OTA: We use the global CDN services,and will have actively firmware update,but first will in our forum to gray scale test for some days,when we confirm it stable will push OTA online update,if find some big bugs need update,we will update new firmware asap and test it again.These make sure the firmware OTA to our customers make much better use.(Customers can download our new firmware from our forum to update also)
One last point: If you plan to buy an Android TV Box, I suggest you skip the keyboard and buy an air mouse with a keyboard on the back. IMHO, much better the the keyboard!
