Q
Platonic said:
The Pioneer website is virtually useless. What is the differences between the following units:
(1) Pioneer VSX-1015TX
(2) Pioneer VSX-9100TX
(3) Pioneer VSX-9300TX?
There is a difference in price, but what do I gain or lose by choosing 1, 2 or 3? Are 2 and 3 current year production models? If so, why aren't they on the Pioneer website?
Thanks in advance
All 3 came out this year. The only things the 1015 has over the 9100 and 9300 THX Select
2 vs. THX Select
1 and 3 component video inputs vs. 2 on the 9100 and 9300. All THX Select2 gets you is THX Games mode. Now, here's what the 1015 lacks in regards to the 9100:
1. Reinforced chassis
2. Multi room/multi source capability
3. Audio sync delay
4. THX Select and AIR Studios monitor tuning(Just google AIR Studios!)
5. 12 volt trigger
6. Advanced MCACC with 5 band EQ(the 1015 makes do with the plain jane non-room acoustics equalizing calibration)
7. Hi-bit audio scaling
8. Dual Motorola 48 bit DSP engine
9. On screen display
Here's what the 9300 adds over both the 1015 and 9100:
1. RS-232C serial output for displaying advanced MCACC results on a PC
2. Advanced MCACC with 7 point EQ timing and room correction(the 1015 only had the plain jane non-room acoustics equalizing calibration)
3. 2 x 27000 microfarad capacitors
4. 12 advanced surround modes(i.e. rock, jazz, chamber etc. the 1015 and 9100 only get 8)
5. TAOC insulators(I don't know what that is)
6. Transformer stabilizer
7. And the best part of all, the 2 line lcd fully illuminated learning remote! It's almost 9½" long and 2½" wide. 66 buttons and 4 AA's baby! I've got mine controlling my Samsung TV, Govideo DVD/VCR, HD cable box and of course the receiver. It's got a "system off" button specifically for turning all your components off at once and it's fast. Less than 1 second and it's done...it takes the Cable box's universal remote about 2½ seconds to do the same thing. You can also program a macro with up to 5 commands for example, you could have it turn on the TV and dvd player(it will automatically turn on the receiver so that's a freebie), switch TV to correct input if you are not taking advantage of the receivers video unconversion, and then switch the receiver to dvd mode for audio.
The last bit of info. The 9300 has a detachable power cord. The only Elite besides the 59TXi that does that is the 56TXi, which leads me to believe that they share similiar if not identical power supplies transformers and amplifier sections. Also, the 1015 weighs 34 lbs, the 9100 weighs 39.7 lbs and the 9300 weighs 44.8 lbs(same weight as the Pioneer Elite VSX-56TXi!!!).
Hope that helps.
