neznarf said:
1. I thought I would position my system on the short wall, but now have
doubts after seeing your pics and zumbo's response.
2. Man at Axiom says even tho I have 7.1, I should set up only 5.1
because rears will add no benefit. Sides will fill the room. He also said
he prefers the long-way setup.
So (based on your experience thus far):
Should I consider returning entertainment center?
3. Have you noticed any substantial differences when changing
speaker placements?
4. Do you notice sound problems because of all the wood?
Should I place system on long wall?
Are you happy with 7.1 speaker system?
Note - I renumbered your questions
1) Short wall it probably best. Is it an enclosed room? Why would you want it on the long wall? Reduce reflections? More room for the entertainment center? Post a pic with more description and perhaps we (assuming others get involved) can help. You'll also get more responses in the Room Acoustics forum.
2) He's probably right (especially if you set up on the long wall) though I wouldn't give up my rear surrounds for anything. I think they are great.
3) Absolutely. You've got to get the tweeters to ear level on the mains (when I sit on the floor the sound is significantly different). Toeing in (angling toward you) has affected the sound and I played with it quite a bit before getting it right. Surround speaker height is a little high in my set up (by room constraints) but I've been happy with the placements (see
here for angles and suggestions). The biggest thing is the sub. Many advocate corner placement. In my room that was all wrong. Being almost a box, the reinforcement from the corner accentuated the peaks and nulls. The best location would be right under the TV but the sub is not shielded so until I upgrade - no can do. I moved the sub midway on the side wall. Made a huge difference.
4) I built DIY absorbers (see
here) and those take care of a lot of my problems. I have the front of the right, left, and center speakers a little in front of the entertainment center so no. I do have problems with this cheap light fixture in the hallway outside rattling a certain bass frequencies...but that's not really a problem – more of a fun trick to impress guests with
Lastly, getting rid of the entertainment center was never an option for me. It is easy to sit here, hundreds or thousands of miles away, suggesting this or that from behind the safety of a computer. Most of the suggestions on this site are great – some are great but undoable because of your situation. If you have the money to build a perfect room – by all means, go ahead, and invite me over…I’ll bring the beer. But most of us can’t do that – so we come here to get advice on how to optimize what we have.
So you said, “Just bought similar entertainment center with armoire for a grand after much trial and tribulation.” Very, very, very, very few rooms are perfect (if you read the latest Axiom visit, you’ll see that one of Gene’s complaints was that their listening room was so bad). If you like the entertainment center, make it work for you. It may affect the sound, but hey, you have to live in that house too right?
