Yamaha, Sony or Philips......which 1 to choose
somantak_g
Hello guys & gals,
M new to this community.........so starting a new thread..........m gonna buy a 5.1 or 7.1 A/V receiver with 5.1 or 7.1 speaker set nd gonna hook it up wid ma pc..........initially i will use analog m/c inputs for the receiver......but soon m gonna buy new sound card wid optical or coaxial output..........i have 19" LCD monitor wid HDMI input........ma budget is 25k to 30k INR max.......nd ma room size is 12' x 14'..............plz suggest me a good 5.1 or 7.1 A/V receiver @ this price range & also plz mention where can i get from Kolkata............
Thnx in advance.............
nibhaz
nibhaz
30,000.00 INR = 617.665 USD
India Rupees United States Dollars
This might help others, help you.
somantak_g
so nibhaz..........can u plz help me in this matter...........??? coz i need 1 gud A/V receiver wid 5.1 or 7.1 speakers badly.............
nibhaz
nibhaz
I don’t have a clue what is available in India, or what the pricing is like there. If you could provide links to any online retailers that you would consider purchasing from or websites for brick and mortars in your area, I would be more than happy to look at what’s available, and provide an opinion.
Just based on the three options you’ve provided thus far, I would probably just by the most expensive Yamaha within your budget.
somantak_g
i only got this link............how about this one.........???
http: // cgi.ebay . in/YAMAHA-RX-V361-Home-Cinema-NS-P110-Speaker-System_W0QQitemZ270428622814QQcmdZViewItemQQptZLH_DefaultDomain_203?hash=item3ef6cd4fde&_trksid=p3286.c0.m14&_trkparms=65%3A1|66%3A1|39%3A1|293%3A1|294%3A25
somantak_g
just remove <spaces> between http: & // & cgi.ebay & . & in
Adam
Adam
The system that you linked to is similar to, but older than, the Yamaha YHT-195 home theater in a box set.
I'd suggest that you contact your local Kolkata dealer and ask how much the YHT-195 costs. Your local dealer is Harmony House and can be reached at +91-33-2229 8004. You can get more information about them by going to Yamaha's India site and clicking on "Where to Buy" at the top.
somantak_g
I asked them few days earlier...........they offered me 33.5k INR for YHT-195............i think its overpriced..............can u plz temme any other shop where i can get yamaha A/V receiver...........nd also tell me will this YHT-195 sound good for my room............???
Thnx......
Thnx......
It's not one of those brands, but Denon has a distributor in India. Here's a link:
http://www.denon.com/distributors/
You should be able to contact them to find a dealer.
somantak_g
but will denon be priced lesser than yamaha...........??? coz m tight on ma budget.....can't exceed 30k INR.............
That is a hard question- it depends on import duties/taxes, local market conditions, money conversion rates, etc. I would definitely contact the distributor to find a dealer and then do the same with Yamaha. If you have a way to see them and find out what differences exist in whether you prefer the operation of one over the other, you'll be happier with what you buy.
somantak_g
ok........i will contact with the distri to find out a local dealer..........
anyways.......thnx for the help..........
As a general rule of thumb, I would pick Yamaha over Sony & Phillips.:D
Just like I would pick NHT, HSU, Aperion, Emotiva, and SVS over Bose.:D
somantak_g
actually i want the best system @ my price range i.e. 30k max..............my importance will be on input/output nd sound quality.................so brand will hardly matter to me..............
ar.prasath
me a Noob here
dude, which place r u from? yesterday i checkd denon dht-390xp @ ezone bangalore.. sounds gr8 compared to onkyo-3100 (though i cldnt try comparing it with onkyo-3200 which was not available for demo). they offered denon @ 30k. You can try that. while lemme check yamaha.
somantak_g
m from Kolkata................so u r telling that ezone stocks denon yamaha & onkyo............???
lsiberian
lsiberian
Good receiver!
somantak_g
can anyone plz give me any dealer of yamaha or denon A/V receiver with speaker set in Kolkata, India...............
lsiberian
lsiberian
Your best bet is to go to each company's website and look it up there.
