A few Setup Tips.
dude, in the process of helping u out, atlast i bought the denon htib..
now the problem is..
i have my ps3 as bd/dvd player.. connected htib.. video is through hdmi between ps3 n receiver..then receiver to hdtv.. clarity is well n good..
optical from ps3 to receiver for sound.. then i changed audio output in ps3 to optical..but NO SOUND at all.. can anybody help me out...thanx in advance.
Hey Hi ar.,
Denon, sounds cool man.
Problem: PS3 = no problem so far.
* Got you, SOLUTION is: you don't need the digital Optical cable from your PS3 dig. Opt. Out. Because you already have the HDMI connection taking care of the Audio/Video of all the type of discs that you can throw at your PS3.
** In the Audio Menu Setup of your PS3, from the Digital HDMI menu one:
1. Select "Multich Linear PCM".
** In the digital Optical audio setup: Select "Bitstream".
---> But you don't really need to use that connection, because you are already all set, from the HDMI connection. Comprende?
The HDMI connection will allow you to decode all the audio codecs from your PS3 and your receiver, no problem at all.
---> But if you really still want to use it, in addition to the HDMI one, just Select: Bitstream, from the audio digital optical out, of your PS3 menu. That's all there is to it.
===>>> Additional tips.
* AUDIO Setup: Under digital HDMI, Select all.
HDMI Audio Out:
1. Mutich Linear PCM = Yes (Select)
2. Stereo LPCM = Yes (Select)
3. Dolby Digital 5.1 = Yes (Select)
4. Dolby Digital 6.1 EX = Yes (Select)
5. DTS 5.1 = Yes (Select)
6. DTS 6.1 EX = Yes (Select)
7. DTS 6.1 ES = YES (Select)
8. DTS 96/24 = YES (Select)
9. LPCM 44.1 khz = YES (Select)
10. LPCM 48.2 khz = Yes (Select)
11. LPCM 88.2 khz = Yes (Select)
12. LPCM 96.4 khz = Yes (Select)
13. LPCM 176.4 khz = Yes (Select)*
14. LPCM 192.8 khz = NO (Don't select)
Digital Optical Audio Out = Bitstream (Select)
* Optional.
Now, for VIDEO Setup in the Video menu from your PS3.
HDMI VIDEO Out:
1. YCbCr or RGB = Automatic (Select)
2. Super White = ON (Select)
3. RGB = Full (Select)
4. 1080p/24 = Automatic (Select)
5. SD-DVD Upscaler (for 1080p output) = Normal (Select)
*6. Automatic Setup for HDMI display = 1080p (Accept)
*7. Automatic Setup for HDMI choices = Yes (Accept)
* Depending on your TV display resolution capability (But these are pretty Standard Selections).
____________________
Last but not least:
Read the manual from your PS3 throughout and thoughtfully.
And do the same with your new Denon A/V receiver.
Let me know how things work out?
Cheers,
Bob
P.S. If your satisfied with the results, try to give a nice hand to somantak_g.
I'm sure he'll greatly appreciate that, and working as a team is very rewarding at the end.
