YAMAHA RXA6A--- HOW MUCH WATTS I GET CONNECTED 3 SPEAKERS WITH 4 OHM (front loud speakers and central speaker) AND 4 SURROUND SPEAKERS 6 OHMS
Chris Anderson
I know to switch,,eco mode,, off and put settings to 8ohm minimum to get max power from the Yamaha RXA6A but how much power I get to each single speaker if 3 of them are 4 ohms and 4 of them 6 ohms
everettT
everettT
Wattage doesn't work that way as at any given spl or specific voltage applied it will be different for a specific speaker or dummy load. Is their a concern you have about something, what speakers?
Chris Anderson
This speakers what I talk about are----
Dali oberon 9 (2 of them)
Dali oberon 3 (4 of them)
Dali vocal (1 of them)
Chris Anderson
I check the Yamaha RXA6A specifications
And I know for speakers with 4 ohm power for two Chanel speaker will be 284 Watt
BUT what about 7 of them ???how much watt I get for each single speaker ???
Chris Anderson
Dali oberon 9 have 4 ohm
Dali oberon 3 have 6 ohms
Dali vocal have 3 ohms
everettT
everettT
Ok, are you having an issue?
The Dali oberon 9 has a 90.5 sensitivity rating meaning that 1 watt or 2.83 volts will drive the speaker to 90.5dbs at a distance of 1 meter.
There are several calculators that can determine 6our needs, but I'm not sure that's what you're looking for in your first post.
everettT
everettT
That's not how speakers and power work. Each speaker will draw the power necessary to play a signal at a given SPL based on your source. You will never (unless you start playing square wave files) have a total power draw equal amoung your speakers, each one play the signal that is pre determined by your source material, ie music or movies and the differences between each.
Chris Anderson
Yes I got a issue because I don't understand some things so this is why I registered over here to find out my answer Dali oberon 9 have 400 watts RMS
YAMAHA RXA6A--- send max power for speakers with 4 ohms on two channels 284 watts planty for me I am happy about that BUT ...
Example what I talk about and what I mean by my post---
Yamaha RX-A6A 1kHz PSweep (7CH) – 8 ohms
With 7CH driven, the RX-A6A limits power to 52 watts.
BUT ....what if you have 3 speakers 4,ohms and 4 speakers 6 ohms 7 all together so how much power I get on 7 channels connect together
The measurements I find out show calculations on speakers with 8 ohms 2 channels and the same speakers with 4 channels that's all but nothing about 3 speakers with 4 ohms and 4 speakers with 6 ohms
isolar8001
isolar8001
Your Dali Oberon 9 have zero watts.....400 watts is just a theoretical limit on how much they can take before they burn up.
You could actually fry them with 20 dirty clipped watts.
Chris Anderson
You know what I mean the numbers of course it is how much max power they can handle
But what about my answer for question
isolar8001
isolar8001
Hard to say what your actual power would be....if the Yamaha limits to 52 watts RMS at 8 ohms, you might get slightly more at 4 ohms....Not a whole lot more.
That would depend on Yamahas protection circuits.
It's really nothing to be concerned about.
F
fmw
Most people with speakers of normal sensitivity will rarely use more than 20 watts per channel. Personally I don't get much above 5 watts per channel. I think you will be OK. You have to understand that 1 watt per channel will be as loud as the sound of a gas lawn mower running right right next to you. Ever see a homeowner wear ear plugs while mowing? You are worried about nothing that matters.
Chris Anderson
Yes that part I know will be defo more from 52 watts per Chanel BUT HOW MUCH EXACTLY THAT'S THE QUESTION because what is the point to buy expensive speakers when on 7.1 you get little power I want to watch movies close to real cinema experience loud powerful with exited experience
Verdinut
Verdinut
The power output of an amplifier doesn't basically depend on its protection circuit, but on the capacity of its power supply.
ryanosaur
ryanosaur
It's an easy question to ask, but you'll need to figure it out for yourself... as it's not an easy answer. @gene has done vids on this...
Here's one:
Another:
Dunno why you think you have a problem. But if you are concerned that you need more power, go out and buy some Amps. It doesn't change that the Amp will still only deliver about 1w per Speaker at 8 Ohms to achieve the rated sensitivity of said Speaker.
3db
3db
We need more information from you. How big is the room? How high is the deiling? How close do you sit from both the front and rear speakers? We need actual measurements. The thing is the bigger the room and the further you sit away from the speakers, the louder you have to play to get to the levels you want. The other thing you need to understand that 52 watts is with all channels driven. I own hundreds of movies and NONE OF THEM have equal output across all 7 channels (all channels driven) The surround channels only use a small part of the audio bandwidth and almost never run the full audio bandwidth. The main draw on an AVR power are from the three front speakers. If you are using subs, the power draw will be reduced even further. You need to understand these concepts first. Get us the room dimensions so we can help you out.
isolar8001
isolar8001
His Yamaha is steering the wattage around so as to not exceed what the power supply can deliver to avoid clipping....same thing all AVR's do. I call it protection, probably not the right term.
I think the OP just wants to see a big number, not 52.
^This. While powering a 4 ohm load for 2 speakers you are not "getting" 284W to them, you are getting however much the speakers need at that time as long as the power supply does not choke. As 3dB is asking, if you sit far and have a large room, those demands change dramatically.
I've had 3 4 Ohm speakers (91dB sensitivity) on a flaghsip AVR in a large room and sitting relatively far ~12ft and it struggled when turned to high levels. I moved them to an amp and never had any further issues. Reality is, predicting this isn't that simple, you might not have the answer until you have the gear.
Verdinut
Verdinut
It looks like the OP wants high SPL levels but is he getting them? If his AVR cannot drive his speakers to his liking, then he needs a more powerful AVR.
Usually in a typical home listening room, only a couple of watts are needed to drive speakers on the average. 52 watts and more on a loudspeaker represent a very high volume and is the OP interested in getting deaf?
I think your questions have basically been answered. That is, music and movie contents vary a lot, the signal is not a steady sine wave but a combination of sine waves that vary with time. That is a fact!
So it is not possible to answer your specific question as to how many "watts.....", with reference to the power output "sweep test" or when watching movies at cinema level using whatever speakers. It really cannot be answered correctly even if we try!
Sweep tests and movie signals are very different on the magnitude and time/duration basis. For example, sweep test such as those Gene conducted on the A6A was based on continuous sine waves at 1 kHz, and the test duration was not "continuous", not literally, but are of a short duration (like minutes??). Movie signals are nothing like that!
Now if you want to know (not sure if you do) how much power the A6A can output when connected to 4 and 6 ohms resistor test loads, take a look of Audioholics and Audiovision.de's tests and you will see some results for the A6A, lucky you..
Yamaha RX-A6A (review) (audiovision.de)
Their bench tests show, using 1 kHz test signal, at unspecified THD level, but presumably 1%:
1) 219 W 6 ohms, 2 channel driven..................... Calculated voltage = 36.25 V
2) 270 W 4 ohms, 2 channel driven..................... Calculated voltage = 33.59 V, current = 8.22 A/ch.
3) 123 W 6 ohms, 7 channel driven......................Calculated power = 861 W, V = 27.17 V, current = 4.53 A/ch.
4) 151 W 4 ohms, 5 channel driven......................Calculated power = 755 W
Using the power formula, P = V^2/R = I^2*R (based on a resistor load that is typically used for such bench tests)
where P is power, V is voltage and R is the resistance, the above calculated values can reasonably be assumed to be the output voltage, current, and power limit.
Based on the Audiovision.de's test results shown in 1) above, it would appear that the RX-A6A can output about 36.25 V at 6 A, or 32.86 V at 8.22 A on per tested channel basis, for the duration of such tests that probably last no more than a few minutes.
Based on 2) above, the current limit would be about 8.22 A, but based on Gene's test, I would use 8.4 A or 16.8 A for 2 ch (see linked test by Gene below).
Based on 3) above, it would appear the A6A's power supply can output 861 W for the duration of the test, for 6 ohm test load
Yamaha RX-A6A 9.2CH 8K AV Receiver Bench Test Results! | Audioholics
Now, as an example, if you have 3 4ohm resistor and 4 6 ohm resistors all connected to the A6A, then the 4 ohm loads will draw current up to the point the power supply cannot handle, same for the 6 ohm resistors, when you gradually increase the volume dial.
So let me do the following tests (on paper, calculated only, obviously):
As you wish, I would connect all speakers as you mentioned to the A6A, and increase the volume until the nanny stopped the test.
Just prior to the nanny stopping the madness:
Based on the unit reaching it's current limit of 8.4 A*2 = 16.8 A first, as dictated by the 2 channel 4 ohm load test:
Apply Ohm's law, that is V = I*R, so V = 8.4X4 = 33.6 V, that's within the calculated voltage limit of the A6A.
So let's use 33.6 V as the voltage limit for the case of having three 4 ohm loads and four 6 ohm loads:
Power into the 4 ohm load = 33.59^2/4 = 282 W, or about 2*282/3 = 188 W into each of the three 4 ohm resistor load
Power into the 6 ohm load = (2*282)/4 =141 W into each of the four 6 ohm resistor loads.
Total power output = 3*188+4*141 = 1128 W, that would exceed the power limit based on Audivision.de's test with 7 ch driven into 6 ohms, that is a total of 861 W. We can use the ratio 861/1128 = 861/1128 = 0.763 as a correction factor to estimate the maximum output into you three 4 ohm and four 6 ohm loads, so the final estimated outputs will be:
188*0.763 = 143.4 W for each of the three 4 ohm loads, and
141*0.763 = 107.58 W for each of the four 6 ohm loads.
The above worked example are based on:
a) Use Gene's bench test results on the A6A to calculate the assumed current limit based on the 4 ohm test.
b) Use Audiovision.de's 5&7 ch power output results for the 4 & 6 ohm loads (Gene did not include those tests)
c) Use the results based on 1% THD, and assume (not specified) Audiovision.de did their test based on 1%
d) Obviously such sweep tests are done using resistor loads, not actual speakers
The results are not "continuous rating", not literally, but the term "continuous" are often used by reviewers if they use continuous sine wave test signal as opposed to sine wave pulses, such as x second on, y second off etc.
@gene can tell us the actual duration of the sweep tests and I don't want to guess.
Again, no one can answer your questions exactly because you are talking about watching movies, in that case, it depends on the contents in the movies, that obviously vary greatly among different movies.
And also depends on the characteristics of the speakers, just 4 or 6 ohm is not enough information because those numbers are based on nominal values, and "nominal" is loosely defined. You can possibly have a speaker that has higher nominal value per the manufacturer's own definition, yet it could have dips that could be narrow, or wide, could also be in the bass frequencies, or at higher frequencies. Then there is also the phase angle issue, that may not affect the current draw but it may cause the amp to over heat, or become unstable at some point, resulting in the nanny shutting it down even at lower "watts" output level.
This is just a numerical example, but you can easily see why AVRs are not tested with 4 ohm load for the 7 or even just 5 channel driven conditions. In the two channel driven tests, Gene measured 282 W, the calculated current is 8.4 A, with 2 channel driven, the AVR's power supply will have to deliver 8.4 A per channel, and the calculated voltage is 33.6 V, so if the same output is expected under the 7 ch driven condition, the transformer's VA rating will have to be 33.6*8.4*7 = about 1,976 VA, that would be a huge transformer that probably weight over 30 lbs! For 8 ohm load, that can be cut to half. And that's assuming 100% efficiency!!
I hope this helps, but I suspect it may confuse you more, so, next question.:D
Note: I did this in a hurry, regardless, there may be typos and calculation errors so if other members catch any, feel free to alert me and I will make the necessary corrections.
Edit: I found some errors, hopefully got them all fixed now
