Yamaha Rx-V750 have Manual Parametric EQ?
dohanc
Simple question that I haven't found the answer to yet. Does the Yamaha Rx-V750 have a parametric EQ that the user can manually change like the 1500. The manual does not show the screen to select automatic or manual so I'm not sure if it does. Thanks.
yoss
yoss
I guess all you can do is modifying the center speaker's EQ.
Haven't tried that so far.
Cheers
Z
zumbo
You can't change the PEQ on any of those units. Only the GEQ. However, there is an option on my 1400 to choose what frequencys the PEQ favors. The choices are, FLAT,LOW,MID, & HIGH.
