OK, disconnected high level inputs to sub amp and reconnected RCA jack and cable between receivers 'subwoofer 1' output (page 11--ref 8) and line-in of sub amp. Note---if I touch the center pin of this connector cable, a loud hum is output from the sub-woofer speaker--so, know for certain subwoofer amp is ready for LFE signals.
Plug test mic into front jack on receiver and Auto-set-up is enabled. Running test in 'auto mode' signals are sent and heard from all 7 connected speakers but not sub.
PRE CHECK----sends 'noise' to each of 7 connected speaker and indicates that noise is also being sent to SUB but no output from it.
MAIN CHECK---a swept tone is sent to all 7 speakers only---no indication that tone is being sent to sub and nothing heard from it.
CALCULATION---during calculations no mention of sub
LEVEL-----------again, no mention of sub
Under RESULTS--SP shows 3/4/--- suppose that means 3 fronts, 4 rear, nothing else.
What am I missing? I preset speakers to small and tried every combination I can think of.
