G
ggunnell
All I can find is the ability to assign the presence amp to zone 2, as described on pages 96 and 105can somebody point me to the page in the manual that discusses the "assignable power amp"?
Perhaps you could give us a specific product to compare to.Bluesmoke said:Maybe I didn't read the tests right, but is the amp section of the 659 comparable to amps rated at 140w/channel specs at 8ohms?
I'm just going by what I read from the audioholics review. I'm no techie. I'm just trying to make sense with some "real world" numbers.ggunnell said:Perhaps you could give us a specific product to compare to.
Remember the devil is in the details comparing numbers unless the test procedures are identical.
On another tack, I'll give an example comparing the RX-V659 to the RX-V2700 using Yamaha's specs in the .pdf product manuals:
The 659 is rated at 100Wpc into 8 ohms, 20-20k Hz, 0.06%THD, seven channels driven.
The 2700 is similarly rated at 140Wpc, 0.04%THD
But the short term dynamic power delivery (IHF) into low impedance loads is considerably different:
659, 245W into 2 ohms
2700, 345W into 2 ohms
I don't recommend 2 ohm loads, but this shows you a difference between the two amps in their ability to quickly dump current into a load.
What does all this mean? The review wasn't very clear. I've seen Yamaha rate it at 100w/7channel, 115w/7 channel, and then saw Best Buy's description as 140w/channel with total of 980w. If the amp is "class leading" in terms of power, does this mean it boasts more power than the Pioneer 1016 (which at 120w/channel) is probably the Yamaha's closest competitor?At full continuous unclipped power (132wpc x 1; 8 ohms, 120wpc x 2; 8 ohms – full bandwidth with less than 0.1% THD+N), the RX-V659 still maintained excellent bandwidth linearity with a -3dB point of 65kHz despite we were driving the receiver way beyond its rated 100wpc power specification. Into 4 ohms, the RX-V659 was able to deliver continuous power levels at a whopping 200wpc x 1 and 170wpc x 2 with less than 0.1% THD + N. The amplifier section of this receiver is truly underrated. I never encountered a budget A/V surround receiver that could deliver this kind of power before. Truly amazing.
Blue,Bluesmoke said:I'm just going by what I read from the audioholics review. I'm no techie. I'm just trying to make sense with some "real world" numbers.
Oh geez, here we go again. None of the receivers rate power with ALL CHANNELS DRIVEN.What does all this mean? The review wasn't very clear. I've seen Yamaha rate it at 100w/7channel, 115w/7 channel, and then saw Best Buy's description as 140w/channel with total of 980w. If the amp is "class leading" in terms of power, does this mean it boasts more power than the Pioneer 1016 (which at 120w/channel) is probably the Yamaha's closest competitor?
Please RE-READ my prior post.Gene, your specs on the HTR line are wrong.
huh? The HK is rated at 70wpc into 2CH where as the Yammie is rated at 100watts and I tested it to 132 watts into 8 ohms and 200watts into 4 ohms!feature wise ... the 659 walks all over the 340.
2 channel wattage wise ... the same.
sorry, what I meant was: "the same" as above ... where the yammy walks all over the HK in 2 channel mode.gene said:huh? The HK is rated at 70wpc into 2CH where as the Yammie is rated at 100watts and I tested it to 132 watts into 8 ohms and 200watts into 4 ohms!
The Yammie also weighs in about 4-5lbs heavier.
I don't know about the 1016, but I used to have a 1015. It was no contest. The 5960 did everything better.Doc. said:Probably has been asked before and I missed it, but how does the RX-V659 compare to the Pioneer 1016txv?
Up until about 10 years ago your assesment would have been spot on. But I feel ever since Onkyo entered the 5.1/7.1 discrete surround receiver marketplace their amp sections have suffered compared to their competitors. IMO their last excellent amp section in a receiver was in their 828THX model.Many thanks for the information. I've been shopping for a new receiver for a few weeks, and it certainly seems like this Yamaha has moved to the top of my list, moving ahead of the Onkyo 604. The Onkyp started out ahead, mainly because my last amp, an Onkyo A-7, lasted for 30 years, and I figure that's gotta be worth something. But Gene's "under the hood" discussion strongly suggests that the Yamaha is better built than the Onkyo.
Gene, what's your opinion of the better Marantz a/v receivers (for example, the 9600, 8500, and 7500)? How do they compare to the better Onkyos, Yammies, Pioneer Elites, and Denons?gene said:Their flagship receivers today are stilll quite good but compared to Pioneer Elite, Yamaha and Denon, I feel they fall short in the same price categories.
Marantz is another one of those companies with ups and downs. They were up in the 70's and down in the 80s. They then released the stunning SR-18 receiver which at the time IMO was the best receiver on the market, only to replace it the following tw model cycles with an inferior product. They now seem to be on an uphill again since they joined D&M. Their new line of receivers are excellent. I hope they maintain this.Gene, what's your opinion of the better Marantz a/v receivers (for example, the 9600, 8500, and 7500)? How do they compare to the better Onkyos, Yammies, Pioneer Elites, and Denons?
