Yamaha RX-V573 receiver connection to DCX 2496
pjoseph
I have the above receiver, and I just picked up the behringer dcx2496, for now I will be using it for my sub only, which will be powered using behringer 2500.
I wanted to ask what output I should use from the yamaha receiver to connect to the DCX?
Ther are the following outputs on the receiver
1) Digital Optical
2) Digital coaxial
3) Analog stereo
4) Sub-output
thanks
Why are you using this for the sub or what exactly are you trying to do? The BFD (Behringer Feedback Destroyer), which is also not a sub EQ, but that is what a lot of people use it for.
pjoseph
Using it to boost sub-out signal as well as an eq for my sub, in the future I am sure I will get more use out of it when I add in additional amps for my mains and center.
I have only read good things about it here on the forum.
