YAMAHA RX-V561 sound thru hdmi
John.
The PS3 doesn't bitstream audio over HDMI anyway. You have to let the PS3 decode the formats and send it out via LPCM. In this case, it wouldn't matter that your audio isn't coming from HDMI or not. You can transmit PS3 video over HDMI and LPCM from the PS3's optical connection for the same result. As long as the PS3 is your source, HDMI bitstream audio is a non-issue and using a separate digital audio connection to the receiver is fine.
Hi Dave ,
Thanks for your advice . I really appreciate it .
I guess I will stick with this receiver . Right now , I do not have the funds to purchase a better receiver . Maybe in the futre I will .
Also , the ps3 will be ok for dolby digital , dts etc... ?
Thanks !
John.
Hi Seth ,
Don't worry about the confusion . I appreciate that you took the time to reply !!
John.
Adam , thanks bud for helping me out .
I guess the manual is probably right .
I am just going to stick with this receiver for now .
Unless I win the lottery tonight !! I think it's 16 million . I should be able to get a pretty good receiver with that type of funds lol !
Seth=L
Seth=L
Hi Seth ,
No problem at all.
Right now I am stuck using the core Dolby Digital and DTS on Blu-ray, it still sounds amazing.:D It'll continue to be that way until I find an amazing deal on receiver that has the processing I need.;)
John.
No problem at all.
Yah I understand .
It's funny . I always thought I knew everything about the latest technology in audio gear , gaming etc..
Basically , do not ask me anything about it . I don't know jack !! lol !
