Azz123 said:
Query 1
One asked by many over the years - I understand that the volume level does not work in a linear curve relative to the "numbers on the dial" with today's amps, however - Am I pushing the friendship (apart from that of my neighbours) and life of my amp playing at volumes close to or at the 0dB?
In general NO. 0dB is not the maximum volume setting. The max volume setting will go into the +dB range, but how far depends on the level of the channel trims. If you are curious as to what it is (and the manual doesn't say) set all the channel trims to zero and select an unused input and turn up the volume until it hits max - will probably be +10dB or so if it's like most receivers. So if you've done the calibration, and it sounds like you have, then there is still some headroom above 0dB.
The only caveat is that at 0dB the receiver is nearing its max power and at that level it may get warm or fairly hot. It won't hurt the receiver, but how long can your ears stand that volume?
Azz123 said:
Query 2
Within the Amp's setup under the following:
Manual Setup\Sound Menu\Speaker Set\
There is a setting for LFE/BASS out.
I have the option to choose "Sub" or "Both".
The manual actually does explain it but it is confusing if you aren't familiar with bass management.
If front speakers are set to Large:
Front speakers get a full-range signal (that is the definition of Large).
- If Bass Out is set to Sub, then the Sub gets the LFE (the .1 in DD or DTS tracks). All channels set to Small have their bass (below the xover you set) sent to the Sub.
B. If Bass Out is set to Both, then LFE goes to the Sub AND the front speakers. All channels set to Small have their bass (below the xover you set) sent to the Sub AND the front speakers.
If front speakers are set to Small:
- if Bass Out is set to Sub, the LFE goes the Sub. Bass below the xover goes to the Sub (same as all other channels set to Small).
- Bass Out set to Both is non-sensical. The fronts are set to Small so they will not get any bass below the xover nor get the LFE. LFE and bass below the xover go to the Sub. In effect the receiver ignores the fact that you set Both and acts as if you set it to Sub (because Small speakers by definition do not get LFE or bass below the xover). The manual does mention this fact.
If you don't have a Sub, set Bass Out to Front. LFE and all bass below the xover from channels set to Small go to the Front speakers. Thus, the front speakers are considered Large, regardless of whether or not you set it to Small. Most receivers will not let you set the fronts to Small if you indicate you don't have a Sub.
