Hello. I am trying to understand the technical differences between Yamaha receivers. I have listened to them and like them and they seem to be one of the favored (along with Denon) receivers to most people on this forum. I currently have a 5740 and want to upgrade. I am into the technical stuff, but don't quite understand it all, hence the title, Yamaha Receivers for Dummies. I am sure there are other "Dummies" out there like me that could really benefit from some dummied down, easy to understand infomation.
Please don't laugh if some of the questions sounds stupid or rediculous. Hey, if I don't ask, I'll never know and if I am asking the question, I am sure there is somebody else out there wondering the same thing. This is a long post and if you don't want to tackle the whole thing, I am breaking it up into categories. Please feel free to help out with just one category
I am researching specs on this link:
http://www.yamaha.com/yec/products/compare/compare_rec.htm
Here is where I need help and by all means any more techy info (dummied down of course) you wish to provide, would be greatly appreciated.
POWER RATING
The power rating comes in two varieties. One looks something like this:
POWER RATING -20Hz-20kHz @ 80HMS
and one looks like this:
POWER RATING 1kHz @ 8 OHMS
I am assuming that it is more important to look at the 20Hz-20kHz rating because this is perhaps continuous power? Would the 1kHz be peak power?
The HTR-5740 that I have has a 20Hz-20kHz power rating of 6 x 85 and a 1kHz power rating of 6 x 100. I assume this means that this reciever sends a signal to 6 different channels not including a subwoofer. Since I only have a 5.1 setup, will this mean the power levels stay the same, or since I do not have the sixth channel, it sends more power to each speaker?
Now I also notice that the HTR-5730 reciever lists it's power at 6 ohms:
5 X 103 WATTS @ 6 OHMS
This can throw a newbie off. Why do they do that? Is it because rating it at 8 ohms would be really low and not look very good? I am thinking that maybe sinse this is the most entry level A/V receiver they list 6 ohms to make it look more powerful to the entry level customer?
THD - Total Harmonic Distortion
From the internet searches I did it sounds like this is how much distortion is transmitted to the speakers? It is rated as a percentage like:
THD (%) 0.06%
The higher end models have less THD than the lower models. I have seen the RX-Z9 has a 0.02% THD compared to others that have 0.04% or 0.06%. So would a receiver with only 0.02% have half as much distortion as a receiver with 0.04%? Would that mean it is twice as "clear" sounding? Is there a certain point to where you cannot tell a difference? The HTR-5730 lists the THD% as 0.7%. This must be a typo? Is it suppose to be 0.07%?
Why is there different amounts of THD depending if they rate it at 20hz-20kHz compared to 1kHz? I assume looking at the 20Hz-20kHz is more important?
Frequency Response
It looks like all Yamaha receivers are rated at 20-20kHz. I think this means it plays all sounds in this range which is all a human can hear? So if a speaker was rated up to 30kHz, would that mean it would not even get a signal higher than 20kHz since the Yamaha does not have that frequency response? Or on the reverse side if a subwoofer was rated as low as 10Hz it would not receive a signal lower than 20Hz?
LINEAR DAMPING FACTOR (20-20kHz)
I have no idea what this is and couldn't even guess. I am assuming the higher, the better. The RX-Z9 has 200 or more, while some are as low as 60. The HTR-5730 does not even list one. Would 200 be twice as good s 100?
Pre-out All Channels
I think this means whether or not the receiver has a digital coaxial output that you would use strictly with an amplifier if you wanted to add one to your system (an output for each seperate channel). So if you are not planning to add an amplifier, "No" would be fine? Would it still have a Pre-out for the subwoofer? It looks like the higher end receivers have "Pre-out main - In couplers". What is the difference?
192 kHz/24-BIT DAC'S For All Channels
I have no idea what this is. Some say "Yes", the high end say "Yes, BURR Brown" and some don't list it at all. If it does not list it, should I assume that means "No"?
DSP Processor
I have no idea what DSP stands for. I noticed that it looks like the more processors the receiver has, the better? There also seems to be some 24 bit, but mostly 32 bit processors. Is there a big difference? There are Yss-930, YSS-938, YSS-928, etc. Are these model numbers, power, etc.? Is there som ethat re better than other that I should look for?
I noticed some have different BIT STREAM DECODERS and some have the same one. What is the scoop on this?
What are DSP programs? They list how many DSP programs they each have. Are Surround Programs the same thing?
YPAO
I believe this is a surround sound set up utility exclusive to Yamaha? Does it incorporate a microphone? How exactly does it work? Is the microphone cordless? How much will this help the novice? If it does not have YPAO, can you still manually configure everything?
Some receivers have an "ON SCREEN DISPLAY" and some don't. I am assuming this means on your television screen, not on the little screen on the receiver? Does this just show you the volume adjustment, bass adjustment, treble adjustment, etc. on the TV when you adjust it? Is there something else it does to help with configuring the surrond sound or anything?
SURROUND SOUND FORMATS
I think Dolby and DTS are just competitors, not different technology? Here is a list of all the technologies I see: THX Ultra 2, THX Select, Dolby Digital 6.1, Dolby Digital EX (same thing as Dolby Digital 6.1??), Dolby Digital Matrix 6.1, Dolby Digital 5.1, Dolby ProLogic II, Dolby ProLogic IIx, DTS ES Discreet 6.1, DTS ES Matrix 6.1, DTS, DTS 96/24, DTS NEO 6. I can look them up online and get plenty of info on each seperate one, but here is what I want to know. For the best 5.1 set up, what are the technologies I NEED? For the best 6.1 set up, what are the technologies I NEED? For the best 7.1 set up, what technologies do I NEED? If I only want 5.1, is it a waste to go with the 6.1 technologies or will they make the 5.1 better?
VIDEO UP CONVERSION
I know this somehow upconverts lesser quality video signals and outputs them into better formats depending on the receiver. Does that mean if a receiver up converts to component and I input the signal with regular RCA jacks or S-video that the signal it send to the TV with a component cable will be just as good as if I sent it into the receiver with component cables? If so, how? It is not getting the more "pure" signal to begin with so how does it magically make it a component quality signal?
HDTV COMPATIBILITY
Why wouldn't a receiver be HDTV compatible? Is it because it does not have component outputs? If it does not list whether or not it is HDTV compatible like the HTR-5280 should I assume that it is not HDTV compatible? Does this mean it is also not EDTV compatible?
WIDE-RANGE COMPONENT VIDEO BANDWIDTH
This is measured like:
5Hz-60MHz -3dB
I have noticed some variations on this and assume this is like the pipeline size of the component cables? What do each of the numbers represent? What is "good"?
OTHER
Anything else I missed?
Thanks so much for taking the time to read this and I am positive that any input you have will help me...and any other "Dummies" out there!! Hopefully this will turn into a one-stop Yamaha technical information tool because it can get difficult finding all of this info on this forum or on the 'net.
