Hi, I've purchased a secondhand Yamaha RX-V683 Receiver, I've plugged in all the cables and speakers as similar to my old Marantz SR4600 receiver and according to the new Yamaha manual, but there is no sound at all either from the fm radio or cd player, nor can I get the onscreen display on the TV to show the selection panel on the left, only the background picture shows. My LG TV is a 2010 version. Here's what I've done: I've connected the front 2 yamaha speakers, centre speaker and the subwoofer into all the correct ports. I've connected the LG Blu-ray player into a coaxial port (as only one HDMI for TV), Pioneer CD player and Pioneer tape cassette deck into audio ports and the Yamaha record player into the phono port, the TV is connected by HDMI into the HDMI output jack as per the manual. The paper manual is pretty vague, the online manual much more detailed, has a lot more instructions and with pictures, where I can see what my display isn't doing! I've always set up these receivers with no hassles, but this one is a bit more tricky - I can't let it beat me!!
- thinking my TV is too old and HDMI not compatible to use the onscreen display
- if I can use a newer TV thats compatible, do you think it will fix the sound?
- for sound - thinking of unplugging each of the components back to nothing to only play the receiver tuner or usb etc, and if works, add one component at a time to see which one doesn't work...
