Yamaha in-wall, in-ceiling speakers-yea or nay?
daisydoggie
First post! I enjoy your excellent forum.
I am finally building my quasi ideal HT as we finish our basement. I have been purchasing components slowly for the past couple of years, including:
TV: Samsung HL-R5667W DLP
AVR: Denon 3805
DVD: Sony dvp-CX995V 400 megachanger
Direct TV HD DVR
Pronto TSU6000 remote
L\C\R Yamaha NS-IW760 in walls
Surround Yamaha NS-IW360C in ceilings
Sub: Bic H100 (Just purchased this based on recommendations from this forum)
Monoprice cables (again, from this site).
I will post some pictures and diagrams as construction progresses the next few weeks.
The main goal was to have a clutter free, clean installation that will sound good, look good all at a reasonable price. As such, all the components will be built into a custom entertain wall that will be accessible from behind.
Has any had any experience with the Yamaha Speakers?
ParadigmDawg
ParadigmDawg
You will find that there are not a lot of members here that advocate Yammy speakers; there is just a lot of speakers that are better performers for ~ the same cost.
That being said; if you like the way they sound then keep them. I trust you listened and liked them so that is why you have them?
daisydoggie
Thanks for the reply.
Err um, the speakers are still in the box (I bought them about a year ago to gear up for our basement remodel, which then became delayed until now.) Boo hiss to me for not listening to them before hand. I spent about $400 total on 3 NS-IW760s and 4 NS-IW360c. I know in-ceiling speakers are not ideal but I was hoping someone had some experience with these in particular.(Not that I will change at this point).
mazersteven
mazersteven
I'm not familiar with Yamaha in-ceilings. In fact I didn't even know they made them.
When you install them and "if" your unhappy with the sound. Remember you could always e-bay them and get a good chunk of change back from them. You'd be surprised at what people pay on there for some items.
I hope this is not the case and they exceed your expectations. :D
ParadigmDawg
ParadigmDawg
Put a good sub in there and see how it works out. For kicks; I unplugged my main speakers and listened to just my in-ceilings and sub and it wasnt that bad. If you mainly watch movies down there it will probably be just fine.
Edit:
I see you have a sub; give it all a shot and let us know how it sounds.
daisydoggie
Thanks.
Sometime in the next 24hours I will post floor plans, diagrams, pics, etc. of the projects progress. Hopefully, with your collective help I can decide on 7.1 or 5.1 surround, speaker placement, and the like.
ParadigmDawg
ParadigmDawg
You can always switch out the front 3 when it comes time to upgrade and end up with an awesome set-up. Leave enough speaker wire in the ceiling to run down the wall and into some nice bookshelves on stands (just in case)
daisydoggie
The L\R\C channel speakers will be mounted in-wall in around the DLP, which will also be mounted in wall all in "media wall" similar to this:
About how far would you separate the L and R speakers from the tv?
AVRat
AVRat
That would depend on your room dimensions and seating distance. For a 56" display, 6'-10' is appropriate. 10' will allow for the big screen setup when you upgrade without having to move the L/R.:D :p
ParadigmDawg
ParadigmDawg
Yep, think of a triangle. ~ same distance from left to right and to listening position.
