L
Loose4Bruce
<font color='#000000'>Any thoughts on this receiver?
I'm on a budget. If I had my choice I'd be spending 3X as much and getting an HK 630 or 7300...dang they are pretty machines!!!!!! I have no idea what they sound like. LOL
How about high current. I've read that Yamaha uses a high current design. The online brochure states this, but maybe it is for a different model. A saleman told me that this Yamaha is not high current and yet the stores' website states that it is.</font>
zipper
zipper
<font color='#000000'>The Yamaha HTR series is not in the same class, power-wise, as the RX-V series. The power is rated differently. The HTR is a notch below,hence the price difference.</font>
L
Loose4Bruce
<font color='#000000'>I just did a comparison at yamaha.
The top of the HTR series the 5590 has exactly the same specs as the bottom of the RX-V series-the 1300.
Even when you click on the photos, they don't change except for the text.
Weird........I wonder why they'd do that?
The HTR is actually 100.00 more than the RX-V1300.</font>
Z
zumbo
<font color='#000000'>HTR is mass merchant model. RX-V is specialty merchant model! You draw your own conclusion!
I would try to find a good deal on a RX-V1400!
</font>
aarond
<font color='#000000'>for $399.99 yes
for $499.99 maybe
for list price of 799.99 no</font>
L
Loose4Bruce
<table border="0" align="center" width="95%" cellpadding="0" cellspacing="0"><tr><td>
zumbo : <font color='#000000'>HTR is mass merchant model. RX-V is specialty merchant model! You draw your own conclusion!
</font>
<font color='#000000'>So what does that mean?
The mass merchant model is not the same?
It is built in a different factory by 10 year olds?.
With all due respect I'm coming here for real advice please.......not to read between the lines.
If I was content to draw my own conclusions, I wouldn't be seeking assistance from folks I assume to have knowledge and experience in these areas.
I really want to get the best that I can afford. I'm tired of throwing money at junk.</font>
Z
zumbo
<font color='#000000'>Look for a RX-V1400.
That is my advice!
$567 here:
$559 here:</font>
L
Loose4Bruce
aarond : <font color='#000000'>for $399.99 yes
for $499.99 maybe
<font color='#000000'>It's 899.99 here in Canada which is approximately 650.00 US.
I could order it from a US shop and save over 200.00.....duties and taxes included but then I have no warranty.
It's crazy what we pay for electronics up here.
The HK 630 that i really dig could be delivered to my door all duties and taxes included for 1200.00 CND.
To buy it here would cost 2070.00 CND. &nbsp;
</font>
Z
zumbo
<font color='#000000'>Oh, Canada.
Valuable piece of information!</font>
G
Guest
Guest
<font color='#000000'>They have good prices and a decent selection, but I noticed some Crown poweramps that were extemely cheap yet claimed to be brand new with warranty.
Something about a &gt;100/channel Crown amp for &lt; $1000 that just seems not right.
Perhaps I'm wrong and wouldn't mind having one of those upper end Yamaha receivers.</font>
RX-V2400
<font color='#000000'>The HTR series are made for mass merchandisers like Best Buy. The reguar Yamaha lines like the RX's can be had for the same price as the HTR's if you buy internet, so I hold there is never any reason to buy the HTR models.</font>
G
Guest
Guest
<font color='#000000'>HTR and RXV are the same. &nbsp;This debate between the two lines goes on simply because of assumptions and appearances. &nbsp;The best rule of thumb when deciding between a HTR or RXV unit, is to just get the one that is cheaper. &nbsp;The crossover between the two lines appears at the ~$800 level of units. &nbsp;There may be only a few minor differences in the number of features, but the build quality is the same. &nbsp;
&nbsp;
</font>
Z
zumbo
<font color='#000000'>There are differences. Big differences. You have to really feel like looking.
</font>
G
Guest
Guest
<font color='#000000'>the differences are only cosmetic. &nbsp;one line uses silver lettering and the other uses gold...they are the same models</font>
Z
zumbo
<font color='#000000'>I have read it before, &amp; it plainly states that the HTR is rated at 1k. It states that the RX-V is rated 20-20000. This means something to me.
Also, I looked at a HTR in Best Buy before I chose to order a RX-V. The HTR looks cheap.</font>
RX-V2400
<font color='#000000'>You can not say &quot;case closed&quot; as if this is the end of it all. There are a lot more difference between the models than this thread has so far gone into.
I have it on good authority that the outsourcing of the gold paint for the HTX versions are negotiated using a different vender protocol than that used under the manufactoring specs. of the RX-V's silver paint.
A more important issue to note is that the RX-V's are only mirrored by the HTX models at the very bottom of the product range. The best HTX model is not very good and when I last saw it at BestBuy was nearly as much as I paid for my RX-V2400. This is the real issue here. Don't pay mass-marketeres high markups for bottom end products when specialist internet dealers sell the top of the range highly discounted.</font>
Z
zumbo
<font color='#000000'>Exactly! Anyway, how can you test one to know when all the speaker options s**k?</font>
G
Guest
Guest
<font color='#000000'>&quot;I have read it before, &amp; it plainly states that the HTR is rated at 1k. It states that the RX-V is rated 20-20000. This means something to me.&quot;
&nbsp; &nbsp;
&nbsp; &nbsp;
HTR Units:
http://www.yamaha.com/cgi-win/webcgi.exe/Specs/?gAVR00010HTR-5560
http://www.yamaha.com/cgi-win/webcgi.exe/Specs/?gAVR00010HTR-5660
RXV units:
http://www.yamaha.com/cgi-win/webcgi.exe/Specs/?gAVR00010RX-V640
http://www.yamaha.com/cgi-win/webcgi.exe/Specs/?gAVR00010RX-V740
Why does this mean something to you? &nbsp;Maybe I've just been reading the other &quot;yamaha&quot; website all this time.
</font>
Stryf3
<font color='#000000'>There are a couple of differences between the 1300 and the 5590. &nbsp;The 1300 has preouts, and the Yamaha label and feet are different colors, that's it. &nbsp;If you can get a great deal on the 5590 and don't need the preouts then go for it. &nbsp;Don't let these people tell you that the amplifier sections are different or any other such nonsense. &nbsp;Having said that, the only reason I went with the 5590 was I got it for $400 from a friend who works at BB.</font>
