Hi Guys,
I'm after some advice. My Yamaha GX-505 system is not picking up CD's like it once did. I put one in the tray, hit play and all it makes a soft cliking noise and a whirring buzz type noise, then opens the tray after failing to detect the CD. I have to repeat this process 5 or 6 times until the unit will finally play a CD (but it tends to skip if the unit is knocked gently). The problem has gradually been getting worse over the last 12 months. I've used a cleaning CD to remove any dust but it has not corrected the problem
Any ideas what may be wrong with the unit. I really like this stereo and don't want to part with it - can it be fixed?
Cheers,
Greg Robertson
Benalla, Victoria, Australia
