My Pick:
crashguy said:
I had the same decision to make. I went with the Yammie because my last one was a denon 3802 and I wanted to try something different, but I think either would be a very good choice.
Agreed -- either would be a very good choice.
The Denon 3805 was named 2004 A/V Receiver of the Year here.
If you check out the Audioholics Product of the Year thread, you will see that I queried TPTB regarding why they named the Denon over the Yamaha 2500. You should definitely check out the response.
If you read the reviews on this site, to me it sounds like the Yamaha was reviewed a bit better--even though the Denon was rated the better overall receiver at year-end. The DSP and YPAO auto EQ and room set-up functions were definitely better on the Yamaha. On the other hand, the Denon's amplifier was the better of the two, according to TPTB reviewers here.
I own the 3805 and like it -- but I HATE the remote control.
If you get the Denon, plan on spending some more $$ to get a "real" remote that has some quality built in.
But again, either is a fine choice -- you really cannot go wrong.
Zarg
