Y splitting sub out
G
Grandzoltar
Should I use a y splitter to utilize the L and R inputs on my Vtf2 mk5 or just plug into the single LFe input. Anyone have experience with this subwoofer.
William Lemmerhirt
William Lemmerhirt
Single is fine.
Using both just raises the input sensitivity, but won’t change the power output. Can be helpful to turn it on at lower volumes, but that’s rarely an issue. Also, bass is mono so nothing to worry about there.
everettT
everettT
FWIW the reason I mention single (lfe) is that it normally disengages any filtering by the subs internals.
bigkrazy155
Thoughts on this? It struck me as something to get a second opinion on.
William Lemmerhirt
William Lemmerhirt
Putting the sound signature of the amp into your subwoofer...W. T. F.....
shadyJ
Speaker of the House
Staff member
That video is nonsense for a list of reasons too long to get into here. You should avoid connecting the sub to high level inputs if possible.
Unless you are prepared to turn the subwoofer integration into a big project, just use the subwoofer output on your AVR.
William Lemmerhirt
William Lemmerhirt
That's exactly the same part that made me ask exactly the same question. Thanks @shadyJ
I liked when he said, all amps sound different, I can’t tell you why but that’s just the way it is. You have to trust me. Wow. Can’t believe he’d say that with a straight face. Lol
I wouldn't bother listening to ol' Paul....he's a bit too much into audiophoolery for my taste. Besides, I dislike watching videos in general, but his especially.
bigkrazy155
I don't know, this guy Gene has some good videos :D
