Y adapter to 2 receivers-Dangerous?
ahblaza
ahblaza
Yes there is still a problem, the receivers outputs will load each other with the same low impedance load, whether they are on or off. Not good.
Your cheapest solution is the switch box, the most seamless solution is a buffer amp. ATI have one that can be configured as I outlined.
Mark (TLS) if Kurt were to use the L&R sub line level inputs with each receiver respectively, would this be an equivalent to using a dual input buffered amp? :confused: Just thought I would ask. :)
Jeff
ahblaza
ahblaza
Despite what Rick says, the other Mark is okay too. :)
Hey my man, good to hear from you as always.:D Yeah the other Mark is more than OK too, but the Doc is in the house :) Take care.
ahblaza
ahblaza
Thanks Mark, Mark, and Ahblaza for suggesting the switch box.
I guess I'll have to suck it up and press two buttons. Life can be such a 8itch!:rolleyes:;)
You're welcome my friend. Suck it up, push the buttons and be safe. ;)
Cheers Jeff
Jeff
I have already stated that that is so.
