L
larry7995
I listen to a lot of XM in my truck and I thought it would be cool to have the internet version in the house played over my stereo. Well I set up a computer in the HT room and started the XM feed over the internet and it really sounds bad. I thought it was just my stock speakers in my Colorado but it sounds much worse in the house. I wish there was a version of satellite radio with less severe compression.
OttoMatic
OttoMatic
Hi Larry,
I don't have any experience with XM, but I've used Sirius for a few years now; I'll just assume they're similar.
My usage has been limited to the home only, no cars. I use a relatively cheap "Sportster" receiver feeding an analog signal to my preamp. We normally use it for background music; I don't think I've ever taken a seat and listened critically -- there's just no point!
However, I think you may be able to improve your sound quality, if you are willing to pay another bill (at least that's how it would work for Sirius). The Internet feed for Sirius is super-bad. It's convenient at work with headphones, and it's OK in my office if there's nothing else to listen to, but it sounds pretty bad. Try installing a receiver in your system that picks up the satellite signal directly. I think you'll find the sound much improved.
Gimpy Ric
Gimpy Ric
Moderator
Get Directv, I have it, and XM radio is included. I listen to it all day long, near CD quality, if not a bit EQ'ed like all radio. At least it's not compressed like an internet stream.
F
fmw
On a computer, you might as well listed to the internet radio stations. As a group they are pretty similar to XM but they are free.
W
White GS
You can adjust the bandwidth settings on the XM browser. I believe its on the bottom left of the window. Click on the settings button and select high bandwidth. Should make SQ better.
O
ogewo
I second this suggestion. XM is great, but check out sites like radioparadise.com, shoutcast.com, and pandora.com and you just may find something you like.
