jliedeka
jliedeka
Until recently, I had been just using the stereo audio inputs from my Xbox 360 which only gets you Dolby Surround. I had thought there was some way to get an optical connection but I only had the A/V plus component connectors. Last weekend I spotted the optical connector on the adapter plug. D'oh! What a difference! Mass Effect is so much cooler in Dolby Digital.
I can't believe I was missing out on the full experience for so long. It's like when I upgraded from a 27" analog CRT to the 42" HDTV, only with sound.
Now I definitely need to get a newer receiver so I can hook up my PS2 through optical as well. :)
Jim
G
Gasman
What???? That would not get you Dolby surround.
It would give you stereo.
And could be matrixed in the AVR to Dolby Pro Logic/Neo 6, etc.. depending on AVR
(this would have nothing to do with the Xbox, but what a individual has for an AVR).
I am guessing, that is what you meant?
But yes, optical/coax digital is leaps and bounds over 'stereo rca input'.;)
jliedeka
jliedeka
I thought Dolby Pro Logic could be encoded into the stereo analog inputs.
Anyway, I've always used coax for DVD until I got the Oppo and switched to the 5.1 analog. My receiver won't decode DTS but the Oppo seems to. Plus, I use that for DVD-A and SACD.
I really like the enhanced Dolby Digital circuitry that Yamaha uses. It sounds more lively that straight DD which is still very good. I guess I'm a Philistine. :)
Jim
