Because it is the best, cheapest, easiest and most reliable solution to his problem. This is out side for low powered speakers over some scenic construction. So, it will be mono.
One 70 volt amp will do the job, like I specked. Then he only needs one run of bell wire to the small 70 volt speakers. He sets the tap he needs, and runs the bell wire from one speaker to the next.
This is quick, easy cheap and reliable. That is the most optimal solution for his plans.
