I have paradigm premier 800F front speakers. I have two SVS PB 1000 subs. After I nail down placement issues to even out bass, I was going to get an ATI power amp for the LCR channels.
Right now the right sub is towards the back of the room down the right wall. In the front right corner I was getting so much bass augmentation that things were super boomy. The left sub is in the front left corner. I was going to move that back and use the front L+R channels full range so I would have 4 points of bass.
I am 75% music and 25% movies/TV.
That is just guess work, chances are even whether it makes it better or worse.
Those 800Fs have two 6.5" woofers so probably would tolerate being run full range. However the drivers will be rapidly decoupling from the box below 30 Hz, and that can be damaging in the HT environment.
The F3 is 43Hz. They are ported enclosure so roll off 24 db. per octave below 45 Hz. So they will be 27 db. down by 20 Hz, and 15 db. down around 30 Hz. So probably best to crossover at around 60 Hz if that is an option. That likely will give you the smoothest transition.
With those speakers a power amp is a good idea.
I would use cable to connect the subs, and not Wi-Fi.
What is your center speaker?
