Wireless Connections Possible?; How Do I?
mcfly360
Need Expertise;
Is it possible to connect a blu-ray player and/or AV receiver to my wireless LAN?
If Yes...
How to connect h/w below to wireless LAN:
1. Samsung BD-P2550 BR Player
2. Onkyo TX-SR705 Receiver
Cpt.America
Cpt.America
Do either of those pieces of equipment have networking capabilities?
BMXTRIX
BMXTRIX
Need Expertise;
If Yes...
You will need a wireless bridge to do so. I assume you are just looking for the wi-fi network connectivity so you can take advantage of BD-Live functionality and firmware updates for the Blu-ray player and the receiver has Ethernet for something like music or picture capabilities?
A wireless bridge you hard-wire to your LAN to setup, then once it is setup, you can plug it in anywhere in your home and plug hard-wired Ethernet devices into it, and they will automatically get an IP address for your home network.
Something like this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16833124015
EDIT - that won't work, you need at least a couple of ports... Try this...
http://www.newegg.com/Product/Product.aspx?Item=N82E16833124266
